spoon cams- how many kinds are there?
does spoon make only one kind of cam for both the b16 and b18c? searched the archives but i didn't really find find the info i need. a guy is selling me his spoon cams, just want to make sure that i don't get the wrong ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">does spoon make only one kind of cam for both the b16 and b18c? searched the archives but i didn't really find find the info i need. a guy is selling me his spoon cams, just want to make sure that i don't get the wrong ones</TD></TR></TABLE>
do it!!!!!!!! spoon cams are the ****! depending how ur tuning is done afterwards you should get a nice smooth vtec kick in. i used spoon cams and adj cam gears tuned with dyno and VAFC2 and u get a much more linear power curve. Low cam vtec is set at 5000rpm and high cam switch over is at about 5600rpm i think but they pull real hard. mines putting out 143kw at wheels. cant remember what that is in HP but if it helps it was putting out i think 119kw before...
disclaimer: exhaust and CAI were also used to get 143kw out of my 97' JDM ITR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtierrr »</TD></TR><TR><TD CLASS="quote">
disclaimer: exhaust and CAI were also used to get 143kw out of my 97' JDM ITR</TD></TR></TABLE>
i think hi cam 5900rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97dc2R »</TD></TR><TR><TD CLASS="quote">
i think hi cam 5900rpm</TD></TR></TABLE>
It depends on the tuner.
A skilled Hondata tuner might want the high lobes to come on as low as 3500, depending on throttle position, fuel condition, fuel pressure, spark advance available, what gear you're in....
It just depends.
It just depends.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">does spoon make only one kind of cam for both the b16 and b18c? </TD></TR></TABLE>
Yes, there's only one profile.
They don't provide the most power you can get, but they provide a significant boost to a car that you'd expect to get long life out of, and they're very streetable and very tunable.
In a good tuner's hands, hell, you'd probably still get 26 miles per gallon.
What else have you done to your motor?
it's just a stock jdm 98 spec, though i do have a spoon p73 ecu waiting to be installed. hope the spoon cams and ecu go well together
I had read that the Spoon ECU and the Spoon cams is a great package , I already have the spoon ECU now all want to is to find some one selling his spoon cams for a reasonable price
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote"> hope the spoon cams and ecu go well together
Not so well unless your in Japan, the ECU does better when in the climate in Japan it was designed to run in along with higher octane fuel.
Your better off getting a VAFC and about an hours worth of tuning.
</TD></TR></TABLE>Not so well unless your in Japan, the ECU does better when in the climate in Japan it was designed to run in along with higher octane fuel.
actually i have a vafc, problem is i get a cel when i hook it up ( even when everything is zeroed out!), i don't thing its compatible with obd2b setups, i think some of our european members also experience this problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">i'm getting the spoon cams used for $375, hope its worth it </TD></TR></TABLE>
If you don`t buy them I will seriosly !!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">actually i have a vafc, problem is i get a cel when i hook it up ( even when everything is zeroed out!), i don't thing its compatible with obd2b setups, i think some of our european members also experience this problem</TD></TR></TABLE>
I had no problems with my Vafc-2 on my ITR, think you need to check your connections.
it works fine for a while, then after 4 or 5 days a cel for the map sensor comes up. when i disconnect the vafc the problem never resurfaces. i'm pretty sure i read a post about some european members having a similar problem with vafc's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious »</TD></TR><TR><TD CLASS="quote">actually they make two kinds of cams.. </TD></TR></TABLE>
Actually your right they did, They have the publicly available Street Cams and the N1 Cams which were only avail to their sponsored race teams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M »</TD></TR><TR><TD CLASS="quote">
Actually your right they did, They have the publicly available Street Cams and the N1 Cams which were only avail to their sponsored race teams.</TD></TR></TABLE>
Well, if you want to get that technical, they didn't <u>make</u> <u>any</u> cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">
Made by Honda to Spoon specs I believe.
</TD></TR></TABLE>Made by Honda to Spoon specs I believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic168 »</TD></TR><TR><TD CLASS="quote">man....
you made over 20kw atws?
was your car completly out of tune prior to installing the cams..
what else have u got in the engine to get it to 143kw?</TD></TR></TABLE>
lol,this thread is 2 years old.
