aftermarket gauges in passenger side dash
ive seen ppl put gauges in the passenger side of the dash, like a few inches above the glove compartment. how much work would this be, and where the hell would i start, lol.??
just get the 3 pod pillar, its cheaper (im betting) and its better since u done have to look at the passenger side for readings, u can just look a little to the left.
That's badass - I want to get some put into my car. I still want my pillar pods, but I want gauges for the passenger to see too. I think it would get the passenger a little more psyched up, and into the driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aphelion »</TD></TR><TR><TD CLASS="quote">I think it would get the passenger a little more psyched up, and into the driving.</TD></TR></TABLE>
I think a passnger-side steering wheel would be the best way to get the passenger psyched up for driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aphelion »</TD></TR><TR><TD CLASS="quote">That's badass - I want to get some put into my car. I still want my pillar pods, but I want gauges for the passenger to see too. I think it would get the passenger a little more psyched up, and into the driving.</TD></TR></TABLE>
He's '05, they never joke.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knockout »</TD></TR><TR><TD CLASS="quote">just get the 3 pod pillar, its cheaper (im betting) and its better since u done have to look at the passenger side for readings, u can just look a little to the left.</TD></TR></TABLE>
obviously he's not using them for function
gauges in the passenge side dash are for show cars, the gauges are to far away for you to look at them and try to drive at the same time. and why would looking at a air/fuel gauge or oil pressure gauge get the passenger psyced up.
but if you really want to do it get a drill with a hole saw bit the same size as the gauge and drill into the dash and then slide the gauge in and bezel on the gauge will cover the hole
gauges in passenger side are for show, i have a friend got his Defi gauges inside his glove box, im asking him why and he said to keep theives away, might got a point but i think its a little TOO far to look at the gauges.
I will recommand to install in CD deck or A piller.
Im going to get a set of 52mm gauges soon, perfect fitment in a 1DIN hole
if you got an EK there are special frames so you can put two extra guages
if you got a del Sol (or a car with round vents) you can always fit one in the drivers side air vent (which is not wise if you live somewhere cold and you need to defrost you side windows)
Other than that you could get a center dash frame which Impreza owners use and both you and the co-driver can see.
Haha, you guys are asses
FYI, expensive cars sometimes have center or passenger gauges so that the passenger can see them. It makes for a more exciting ride, that's all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmgrcivic »</TD></TR><TR><TD CLASS="quote">and why would looking at a air/fuel gauge or oil pressure gauge get the passenger psyced up.</TD></TR></TABLE>
I meant more like ... speedo, tacho, boost gauge (I don't know the -meter name for it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aphelion »</TD></TR><TR><TD CLASS="quote">Haha, you guys are asses
)</TD></TR></TABLE>
pics please. vipers, 3000gt's, M roadsters have gauges in the dash b/c there isn't enough space in the cluster. they're not there for entertainment
)</TD></TR></TABLE>pics please. vipers, 3000gt's, M roadsters have gauges in the dash b/c there isn't enough space in the cluster. they're not there for entertainment
Only thing that can psyced up a passanger, is Speedo, Boost gauge and RPM gauge.
when those are equally important for the driver to monitor. or already in the cluster, I dont think any other thing will work
unless you want to show them your 1000 degrees C exhaust temp, when the number is big enough..
KYLE.ECKERT
Apr 24, 2007 06:32 PM
Xemu
17
Nov 14, 2006 08:50 AM
Sassafrass
Jan 26, 2004 03:45 PM
