What other can fit?
Old Feb 15, 2005 | 09:24 PM
sykoracer02's Avatar
Default What other can fit?
I want it to know what other shock can fit on a 93 DA?
Old Feb 15, 2005 | 09:31 PM
..::91TEG-G2::..'s Avatar
Default Re: What other can fit? (sykoracer02)
koni yellows, reds. Tokico blues, illumina's. Bilstine (i think) Kyb AGX, gr2's and there OEM replacement non sport. And not sure about the others.. someone will come in here and finish what i started.. lol
Old Feb 15, 2005 | 09:33 PM
Default Re: What other can fit? (..::91TEG-G2::..)
i mean like stock shock not aftermarket
Old Feb 15, 2005 | 09:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykoracer02 &raquo;</TD></TR><TR><TD CLASS="quote">i mean like stock shock not aftermarket</TD></TR></TABLE>
should of stated so.
94+ shocks will fit, but you gota make sure you get or dont get the fork style in the front. forgot which one it was
Old Feb 15, 2005 | 09:49 PM
i got some eg or del sol shock but i don't know will it fit on my DA
Old Feb 15, 2005 | 10:23 PM
bump
Old Feb 16, 2005 | 11:40 AM
can some one help me
Old Feb 16, 2005 | 11:43 AM
93dabeast's Avatar
they will fit but the front forks are different and they are a little shorter than da struts
Old Feb 16, 2005 | 11:46 AM
Default Re: (93dabeast)
so what sould i do to make it work?
Old Feb 16, 2005 | 12:02 PM
purplegsr's Avatar
Default Re: (sykoracer02)
You can use 94-01 Integra or 92-00 Civic shocks in the front, but you will need new front drop forks from a 94-01 Integra or 92-00 Civic as well. The bottom of the fork will line up fine, but the top part where the shock goes into the drop fork is too narrow on DA forks, so you need to get the wider ones that the DC/EG/EK civics have. If you want to retain the stock brake line brackets, you would also need new ones from a 92-00 civic or 94-01 integra.
As for the rear, you can use 92-95 Civic and 94-01 Integra rear shocks (except ITR) without any modification. However, if you want to use 96-00 Civic shocks, the fork is a little too narrow, so you would have to shave off a little of the LCA bushing to squeeze the rears on.
micah_m
Suspension & Brakes
21
Feb 25, 2010 12:44 PM
shinjitai
Aug 31, 2008 04:13 AM
98GSRDC2
Suspension & Brakes
Feb 22, 2007 02:55 PM
bryan073
Jan 24, 2006 11:34 AM
White cracker yeehaa
Dec 19, 2005 08:03 PM
