will this rub?+44 17x7,215/45/17.....more
Old Jan 17, 2002 | 06:14 PM
screwdriver's Avatar
Default will this rub?+44 17x7,215/45/17.....more
ill have an install early february - drop the 98 lude with tein coilovers
add 17x7 , +44 mm offset volk GTN.
im concerned if it will rub.guys do u have experiences with this?
Old Jan 17, 2002 | 06:16 PM
Default Re: will this rub?+44 17x7,215/45/17.....more (screwdriver)
........and i will drop it 1.25 inch.
Old Jan 17, 2002 | 10:36 PM
EH2DX's Avatar
hm... it should be right around there. if anyone makes a 225/17/40 size tires go with that.
Old Jan 18, 2002 | 04:16 AM
aklucsarits's Avatar
New User
They will be fine. +44mm is just about perfect for a 7" wide wheel. I had 17x7 +45mm with 215/40/17 and they fit perfectly. No rubbing at all, and I did not even need to trim off the tabs on the back bumper cover.
I would not recommend 225/40/17 on those wheels as previously suggested. AFAIK, the only tires that come in that size are Nittos. And with a tire that wide, you may have clearance issues...
Andrew
Old Jan 18, 2002 | 08:19 AM
BluLuder's Avatar
Default Re: will this rub?+44 17x7,215/45/17.....more (aklucsarits)
At those specs you should be fine.
go any wider tire or fatter rim and expect rubbing.
Old Jan 18, 2002 | 09:35 AM
Default Re: will this rub?+44 17x7,215/45/17.....more (BluLuder)
tnx again guys!
H22CD
Mar 27, 2007 12:14 PM
Accord98
May 22, 2003 10:59 AM
lodown414
Nov 4, 2002 10:11 PM
Doogie Howser
Jun 24, 2002 05:34 AM
SuperRice
Mar 5, 2002 09:18 AM
