eagle rods...what size of socket to use for rod bolt??
Old Feb 15, 2005 | 06:23 PM
hi-Powered's Avatar
Default eagle rods...what size of socket to use for rod bolt??
i was installing my eagle rods and i was trying to loosen
the rod bolt because they made it so tight. while i was
loosening the rod bolt it was getting rounded(stripped).
i was using a 10mm (12 point) socket. is this the right
socket or i need a standard socket. what size? i don't
have any standard sockets..
and one more thing. how many ft.lbs should i torque
the rod bolts? thanks..
Old Feb 15, 2005 | 07:00 PM
BEER30's Avatar
Default Re: eagle rods...what size of socket to use for rod bolt?? (numbnut)
It is possibly a 3/8
As for the torque specs, Eagle should have provided
a spec sheet.
Old Feb 15, 2005 | 09:48 PM
HoOridin's Avatar
if u dont know the size bolt and the torque specs.. ur better off not touching the motor.. u dont just slap everything together lik legos...
Old Feb 16, 2005 | 11:10 AM
soLSvtec12kcraze's Avatar
10mm 8-point i believe....
Old Feb 16, 2005 | 01:57 PM
NJIN BUILDR's Avatar
Default Re: (soLSvtec12kcraze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soLSvtec12kcraze &raquo;</TD></TR><TR><TD CLASS="quote">10mm 8-point i believe....</TD></TR></TABLE>
Go away
Old Feb 16, 2005 | 02:25 PM
turbociv's Avatar
its a standard size. NOT METRIC. I believe 3/8 12 point but I dont remember for sure without them infront of me.
Old Feb 16, 2005 | 04:07 PM
hi-Powered's Avatar
yup. it's a 3/8 12 pt. i think the torque is 36 ftlbs. i had the spec written somewhere but i can't find it at the moment. thanks.
Old Feb 16, 2005 | 04:16 PM
Big Teggie's Avatar
Its a 3/8 12pt head on the bolt.
Old Mar 19, 2005 | 09:08 PM
unless they are new age, then they're 42 ft lbs...
those are 5/8....and will handle pretty much any rev you throw at them....
Old Mar 19, 2005 | 09:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soLSvtec12kcraze &raquo;</TD></TR><TR><TD CLASS="quote">unless they are new age, then they're 42 ft lbs...
those are 5/8....and will handle pretty much any rev you throw at them....</TD></TR></TABLE>
The L19 bolts as well as the CA (custom age) are 3/8" diameter.They are a stronger alloy and heat treat.
Glenn
Old Mar 19, 2005 | 09:21 PM
and will handle what you give them....
NH huh? im in maine man. whats good?
Old Apr 20, 2005 | 09:34 PM
boostmywankle's Avatar
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Go away</TD></TR></TABLE>
haha!!!!
kornerk12
Nov 19, 2008 12:34 PM
CustomX113
Nov 12, 2006 05:53 PM
jdm96dc2
Nov 25, 2004 02:13 PM
servion
Jan 21, 2004 09:56 PM
ladysman
Mar 21, 2003 12:08 PM
