Noise under the hood.
Old Feb 15, 2005 | 06:08 PM
Default Noise under the hood.
'99 V6
I think the bearing(s) in my power steering pump are going out. I've recently noticed some noise that sounds like somethings rubbing/dragging and after listening for it under the hood, the uppermost pulley seems to be the one making noise. So... assuming the worst, where's the best place to get a replacement power steering pump for the best price? Local junkyard? My power steering fluid is also looking as dark as oil thats in dire need of replacing; will replacing it solve/lessen my problem? What are my options/solutions?
thx
Old Feb 15, 2005 | 06:51 PM
TxTuner
Guest
Posts: n/a
Default Re: Noise under the hood. ("Hites")
Best thing to do is search ebay and find one that's just been pulled off. OR find a fresh parts car from a private seller. If you buy from a junkyard, you can't be sure if it operates properly till you hook it up.
Old Feb 16, 2005 | 05:25 AM
Default Re: Noise under the hood. (TxTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">Best thing to do is search ebay and find one that's just been pulled off. OR find a fresh parts car from a private seller. If you buy from a junkyard, you can't be sure if it operates properly till you hook it up.</TD></TR></TABLE>
i searched ebay and found nothing before i started this thread. guess itd be best to check daily, cause the cheapest remanufactured ps pump ive found is $210 with a $90 core charge, in other words, a RIPOFF.
ThePurpleHonda
Nov 25, 2015 08:39 PM
z4nd
Honda Civic (2001 - 2005)
14
Jan 22, 2011 12:56 PM
mkrieger500
Nov 21, 2010 12:09 AM
tx95excoupe
Sep 24, 2007 10:19 AM
AMG
Apr 24, 2006 09:14 PM
