Ignition Timing
Old Feb 15, 2005 | 03:35 PM
shortyMT's Avatar
Default Ignition Timing
I know that this question is probably somewhere in these forums, but i can't find it. What is the status about increasing my ignition timing on a 99 sohc civic. How do I do it, and should I do it.
Old Feb 15, 2005 | 04:04 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Ignition Timing (shortyMT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyMT &raquo;</TD></TR><TR><TD CLASS="quote">I know that this question is probably somewhere in these forums, but i can't find it. What is the status about increasing my ignition timing on a 99 sohc civic. How do I do it, and should I do it.</TD></TR></TABLE>
just leave it alone if you don't know what you're doing.
Old Feb 15, 2005 | 04:27 PM
94CoupeEJ1's Avatar
Speaking from general experience on engines I seriously doubt you will gain anything from advancing your ignition on a 99 sohc Honda Civic engine. To my knowledge that is an obd II low compression engine. The computer is going to over ride any advancing you do and even if you could advance it the low compression engine wouldn't benefit anyways. To benefit from advancing the ignition you need a high compression engine with a less sophisticated computer. You need an engine from about 1986. The way to advance the ignition on high compression 90's engines is with a chip.
hmtcrxsir
Apr 3, 2017 05:53 AM
Mike RStein
Feb 21, 2014 11:52 AM
CivicRaping
Mar 19, 2005 12:33 PM
_Endless_
Aug 7, 2002 10:49 AM
