Ground control question spring rates for integra 180.44.67 (something like that) too low
Old Feb 15, 2005 | 02:49 PM
DCTODAR's Avatar
Default Ground control question spring rates for integra 180.44.67 (something like that) too low
I installed new GC on my 98 teg, however I noticed that my front springs matches the Integra spring rates that come originally with the GC (non-custom) which I believe is 200.44.67 or something like that my rear does not. The spring number on the springs indicate almost the same for the rear but has 180.44.64(Civic?). When I looked at the box there is a sticker and indicates that the front and rear sprigns that came with the kit should be 200.44.67. I'm not looking at the actual box right now so it may be a lil off, however i am certain of the first three digits.
I didn't want my rear to be too low, however the rear has no room left for me to adjust any higher. Anyone had this problem?
I know I installed the GC correctly with the modified bump stop and bushings, the GC are sitting on KYB AGX.
The only thing I can think of is the spring rate or sleeves.
I installed the longer sleeves in front and shorter sleeves in the rear.
Also is it necesary to lock the perch? It seems when the car is jacked down the perch is unmovable anyway.
Any feedback will be helpful..thanks
teddy_dc2
Suspension & Brakes
Aug 13, 2007 01:04 PM
Makdaddynuge
Suspension & Brakes
Dec 6, 2005 04:02 PM
Toadfart
Jan 22, 2004 01:42 PM
Boofster
Jul 30, 2003 12:25 PM
VTEConly
35
Jul 22, 2003 08:49 AM
