cam gears
Old Feb 15, 2005 | 12:35 PM
kuki's Avatar
Default cam gears
I have a 95 civic with b16a2. I have just bought ITR cams with valvetrain, it will rev up to 9500. I also have adjustable cam gears. Can anybody tell me how should I adjust them to acquire max power output
Old Feb 15, 2005 | 12:55 PM
strsi's Avatar
Default Re: cam gears (kuki)
there is no set way to adust cam gears to make the most power. Every engine is different. Two people could have the exact same setup, but each engine will most likely require the cam gears to be adjusted to different specs to gain the most out of their motor. THe only way to know what is best for your's is to dyno tune it.
Old Feb 15, 2005 | 01:21 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: cam gears (strsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strsi &raquo;</TD></TR><TR><TD CLASS="quote">there is no set way to adust cam gears to make the most power. Every engine is different. Two people could have the exact same setup, but each engine will most likely require the cam gears to be adjusted to different specs to gain the most out of their motor. THe only way to know what is best for your's is to dyno tune it.</TD></TR></TABLE>
Ditto, keep the cam gears at zero for now.
Old Feb 15, 2005 | 01:45 PM
GeeReg's Avatar
What exactly is the idea behind revving ITR cams to 9500, out of curiosity? I hope you didn't mean ITR valvetrain too...
Old Feb 15, 2005 | 01:54 PM
Banned
Default Re: cam gears (GeeReg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeeReg &raquo;</TD></TR><TR><TD CLASS="quote"> I hope you didn't mean ITR valvetrain too...</TD></TR></TABLE>
I can just see the ownage now.
Old Feb 15, 2005 | 01:59 PM
GeeReg's Avatar
Default Re: cam gears (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">I can just see the ownage now. </TD></TR></TABLE>
I'm not sure if he meant, "it will rev to 9500", as in, he wants it to, or....he bought ITR cams with a valvetrain, which can rev to 9500.
duyfash0
Feb 4, 2010 02:51 PM
misterpsycho
Jan 14, 2008 10:54 AM
rdssk8rcs1
Nov 20, 2007 08:29 AM
ej1252
Nov 10, 2007 04:26 PM
f22abuilder
Feb 16, 2006 06:10 AM
