ITR LMA's and Rocker Arms
Old Feb 15, 2005 | 11:47 AM
ALLphilthyDC2's Avatar
Default ITR LMA's and Rocker Arms
I was just curious to know if ITR LMA's and Rocker Arms would make a big difference in a GSR head???
Old Feb 15, 2005 | 01:19 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: ITR LMA's and Rocker Arms (Philthy415)
The LMAs are stronger, but I'm not sure about the rocker arms. I used a set of Prelude LMAs in my engine, they have the same tension as the ITRs and they won't stick.
Old Feb 15, 2005 | 02:13 PM
Default Re: ITR LMA's and Rocker Arms (LSVTEC 91 Civic)
thanks for the info!
Old Feb 15, 2005 | 02:16 PM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">The LMAs are stronger, but I'm not sure about the rocker arms. I used a set of Prelude LMAs in my engine, they have the same tension as the ITRs and they won't stick. </TD></TR></TABLE>
dont give misinformation about those lma's.....they are the same..here if u need PROOF.... https://honda-tech.com/zerothread?id=571523
Old Feb 21, 2005 | 08:31 PM
allmotorteg_96's Avatar
so you are saying if i put itr lma's in my b16 head they will stick
Old Mar 8, 2005 | 11:08 AM
ELAMINT5's Avatar
Default Re: ITR LMA's and Rocker Arms (allmotorteg_96)
LMA.. lost motion assembly. I have heard of it, now I feel like a dumba$$.
Sorry to highjack your thread here, but if my motor was blueprinted the lost motion assembly would have been checked right? And for the LMA, there is not one better than the other, right? thanks for the help!
Old May 22, 2005 | 05:52 PM
shdriver99's Avatar
I've got a full set of 99 type sh LMA's that I'm not using, they just sit in plastic in my tool box. I know a lot of b16 guys want these LMA's to cut cost down from buying type R LMA's. Pm with any questions!
Old Jun 1, 2005 | 08:21 AM
ajcrx's Avatar
Default Re: ITR LMA's and Rocker Arms (shdriver99)
Hello, My friend recently blew up his 95 gsr and gave me his lmas. Can I put the lmas in my B16a? Do they have to be modded to be installed?
Old Jun 1, 2005 | 09:30 AM
Dan GSR's Avatar
Default Re: ITR LMA's and Rocker Arms (ajcrx)
95 gsr LMAs
are the older type similar to the B16
you want newer GSRs or ITRs
Old Jun 1, 2005 | 11:54 AM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philthy415 &raquo;</TD></TR><TR><TD CLASS="quote">I was just curious to know if ITR LMA's and Rocker Arms would make a big difference in a GSR head???</TD></TR></TABLE>
Not a **** bit of difference, depending on the year of the gsr head, the itr lma's will allow you to run a higher lift cam.
Old Jun 2, 2005 | 01:11 PM
ajcrx's Avatar
Default Re: ITR LMA's and Rocker Arms (PURPLETERROR)
Thanks Dan. I just wanted to know if I can just drop them in to stop the dam ticking noise, not for any performance advantage. My car doesn't look like a eye sore but it sure sounds like one.
Old Jun 2, 2005 | 03:26 PM
teri_vti's Avatar
i run toda spec c' (12.5 lift) in a b16a and havent changed by lma's ...are there any problems that may occur? do i lose performance this way?
Old Jun 2, 2005 | 07:40 PM
JBBNJ609's Avatar
Default Re: (teri_vti)
older (obd1) gsr lmas are like the B16 lmas , def smaller then the Itr lMAs . . just in case you didnt know
i know because i replaced mine in my 94 gsr head
the smaller ones are the GSR ones
Old Jun 2, 2005 | 07:59 PM
shdriver99's Avatar
And the low cost 99 and ^ h22a4 fix for all peoples LMA problems! 65 bucks for a new set from Honda! I think the B-series guys use these with something like a .040 shim or washer!
Old Jun 2, 2005 | 08:10 PM
.nate's Avatar
Default Re: (shdriver99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shdriver99 &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jun 2, 2005 | 08:32 PM
shdriver99's Avatar
Default Re: (.nate)
I think teg type R LMA's are almost 300 bucks. Preludes used to have the cylindrical type but then they upgraded to the coil type because they're good. Just sold my old set for 25 bucks on ebay
Old Jun 7, 2005 | 08:44 AM
B18Tahtaras's Avatar
Can anyone else varify what shdriver99 mentioned about the shim?
Old Jun 7, 2005 | 09:01 AM
.nate's Avatar
Yep...
vc
Dec 5, 2006 10:02 AM
doublek
Oct 23, 2005 10:18 AM
mugenracer
Aug 2, 2004 07:28 AM
bayareatuners
17
Jun 26, 2004 05:02 AM
PM-Performance
Oct 20, 2003 02:35 AM
