Honda S2000 Honda S2000
When installing an aftermarket ECU, does one have to do upgrade anything else? (pistons,cams,springs
Old Feb 15, 2005 | 08:20 AM
GusRock77's Avatar
Default When installing an aftermarket ECU, does one have to do upgrade anything else? (pistons,cams,springs
When installing an aftermarket ECU, does one have to do upgrade anything else? (pistons,cams,springs,etc.) ive heard of people just installing ECU and just calling it a day..along with your basic mods (intake,header,exhaust) ...but ive also heard that you will have to change cams..pistons..etc ...whats the word? ...and whats a good ECU to go with? ..
Old Feb 15, 2005 | 12:20 PM
papa5murf's Avatar
Default Re: When installing an aftermarket ECU, does one have to do upgrade anything else? (pistons,cams,spr
you dont' have to change anything.....
HOWEVER.....
if you get the mugen ecu, then i suggest you get all other mugen parts, intake snorkle, header, and exhaust
if you get the spoon ecu, then i suggest you get all other spoon parts, intake snorkle, header, and exhuast..
this is because these ecu's are programed and tuned to match with other products in their catalog.... so if they claim an extra 10-20rwhp with the ecu, they mean you'll get those gains only if you have their products on the car not some other mix and matched products that you put on the car yourself...
Old Feb 15, 2005 | 12:23 PM
revhi's Avatar
Youll get more hp from each extra part thats added along with the ecu. What are you trying to accomplish?
Old Feb 15, 2005 | 12:54 PM
GusRock77's Avatar
Default Re: (revhi)
...i was just wondering ...im actually planning on going with a comptech supercharger ...but just had that question stuck in my head about ECU's
Old Feb 15, 2005 | 12:55 PM
Nishant's Avatar
Default Re: (GusRock77)
you're fine with a standalone ecu and a supercharger
Old Feb 15, 2005 | 04:18 PM
revhi's Avatar
You dont need a standalone or piggy back ECU unless you are running 8 psi or higher with different injectors. The Comptech ESM is fine. You might see a few hp gain if you run a standalone anyway with some propper tuning.
Old Feb 15, 2005 | 07:36 PM
VtecBlissS2k's Avatar
Default Re: (revhi)
i have a question that deals with the same idea..
Does anyone have a AEM EMS with a stock S or one with just a cat-back or intake, small bolt-ons... did you see a difference in tuning?
thanks in advance
Old Feb 15, 2005 | 07:40 PM
papa5murf's Avatar
Default Re: (VtecBlissS2k)
i've read somewhere when all they had was an aem ems on the car... and nothing else... it pulled out around 15rwhp i believe.....
Old Feb 15, 2005 | 07:57 PM
Nishant's Avatar
Default Re: (03s2kblue)
^ 15-16whp on a stock S is what i have seen with aem ems and a good tuner. that alone sorta makes it worth its price considering what bolt on's give you
Old Feb 15, 2005 | 08:32 PM
papa5murf's Avatar
Default Re: (Nishant)
i think it's worth it... cause think about it .... when you get other bolt ons you'll get even more power..
Old Feb 15, 2005 | 09:33 PM
GusRock77's Avatar
...so when installing the Comptech supercharger, ive heard that it comes tuned right from Comptech ...so i wouldnt need an EMS ...is that right? ...but if i needed a little extra hp, then i could install it?
Old Feb 15, 2005 | 09:54 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GusRock77 &raquo;</TD></TR><TR><TD CLASS="quote">...so when installing the Comptech supercharger, ive heard that it comes tuned right from Comptech ...so i wouldnt need an EMS ...is that right? ...but if i needed a little extra hp, then i could install it?</TD></TR></TABLE>
you are right
Old Feb 16, 2005 | 05:40 AM
Nishant's Avatar
yes, say you want higher boost. then stand alone ecu is highly recommended
Old Feb 16, 2005 | 07:32 AM
GusRock77's Avatar
...the Comptech supercharger comes at 6psi ...and if i went with the 9psi pulley that Comptech offers then i would need an EMS?? ...oh and thanks for helping me out with all my questions
Old Feb 16, 2005 | 08:52 AM
papa5murf's Avatar
yes once you start doing extra modifications to the supercharger, you're going to want an ems...
Old Feb 16, 2005 | 09:21 AM
revhi's Avatar
Default Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi &raquo;</TD></TR><TR><TD CLASS="quote">You dont need a standalone or piggy back ECU unless you are running 8 psi or higher with different injectors. The Comptech ESM is fine. You might see a few hp gain if you run a standalone anyway with some propper tuning. </TD></TR></TABLE>
Old Feb 16, 2005 | 11:29 AM
Nishant's Avatar
Default Re: (revhi)
nice to quote yourself
Old Feb 19, 2005 | 04:16 PM
evil vapor's Avatar
Default Re: (revhi)
necessity and "good enough" are subjective. Running a FMU that boosts your fuel pressure over 100psi might work fine, but I don't prefer that system.
for info on the AEM EMS, go to aem's website. http://www.aempower.com they have a msg board dedicated to the EMS that show's a stock s2k running only a intake with GOOD gains tuned via the EMS. The power is there, just needs tuning.
http://forum.aempower.com/bbs/index.php
Old Feb 19, 2005 | 07:05 PM
Nishant's Avatar
Default Re: (vapor)
interesting reads
Old Feb 19, 2005 | 10:44 PM
fknfast's Avatar
AEM
Old Feb 19, 2005 | 11:04 PM
revhi's Avatar
AEM is the best unit for a boosted S right now. If you go to 9 psi definitly invest in it and some larger injectors. You could also get away with an Emanage, which is what Im tring to do.
SOHC_MShue
Oct 14, 2002 11:22 AM
mattmw88
Feb 1, 2002 01:58 AM
