Bottom end question?
Old Feb 15, 2005 | 06:45 AM
fkncivic's Avatar
Default Bottom end question?
Rod bolts and rod bearings can be done by taking the oil pan off and without any machining correct?
Old Feb 15, 2005 | 07:05 AM
t0p_sh0tta's Avatar
Default Re: Bottom end question? (fkncivic)
Yes, sir.
Old Feb 15, 2005 | 07:07 AM
fkncivic's Avatar
Default Re: Bottom end question? (t0p_sh0tta)
i thought so but wasnt too sure, thanks man
Old Feb 15, 2005 | 07:16 AM
NJIN BUILDR's Avatar
If your changing the stock bolts to ARP's the rods need to be resized.If the rod bearings are hurt then so are the mains.
Glenn
Old Feb 15, 2005 | 07:17 AM
fkncivic's Avatar
Default Re: Bottom end question? (NJIN BUILDR)
nothing is hurt i was just wanting to beef them up but your saying that in order to change to arp bolts i have to get the rods resized?
Old Feb 15, 2005 | 07:20 AM
Yes the ARP's have more press fit.They distort the rod slightly and need to be honed round again.
Glenn
Old Feb 15, 2005 | 07:22 AM
fkncivic's Avatar
so should i use the old rod bolts or just buy new stock replacements untill i can afford to build the bottom end?
Old Feb 15, 2005 | 07:24 AM
Just leave it alone until you can do it correctly.
Glenn
HRubss
May 6, 2014 05:08 AM
TheCrimsonGhost666
Dec 24, 2009 02:24 PM
TURBL0W
Dec 1, 2004 06:23 PM
untitled
Jul 2, 2003 11:25 PM
2020ls
Aug 20, 2002 03:38 PM
