Turbocharging a B20 Vtec
I have a B20 Vtec in my 2000 Honda Civic Ex. Was planning on turbocharging it soon with a Turbonetics T3/T4 system. Just wondering if I should buy the T3/T4 system that is made for a B16 Vtec or a B18 Vtec, since they don't make a turbocharger specific for my engine? When I do put the turbo on should I get sleeves put in the engine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZeRo AsSault »</TD></TR><TR><TD CLASS="quote">You definatley want to sleeve the block, since the b20 cylinder walls are real thin and dont handle boost well stock.</TD></TR></TABLE>
Depends on what his power goals are.You could safely run 7-8 psi which would probably net around 250-270.With a good tune anything is possible.
Also i believe all b series manifolds are interchangeable.
Actually I didn't buy it with the B20 Vtec. I had it installed because the guy who installed had a Civic with a B20 Vtec and a Civic with a GSR motor in it and the one with the B20 Vtec was faster. He has not had any problems with the B20 Vtec and has made a lot of passes with it. He also recommended the B20 Vtec because of the torque and I think it produces more horsepower also. I'm planning on getting it dynoed before I get the turbo put on and then I'll know for sure. I have beaten stock Civic Si's and Vtec Prelude's. I don't even have exhaust, it's just all motor right now.
i did 243whp on a pretty much stock b16 with dyno tuning
almost did the crvtec boost idea, but yeah if u want more than 8lbs get it sleeved if not yeah any kit will work, i used a modified drag kit with the ball bering option
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bucbaby »</TD></TR><TR><TD CLASS="quote">i did 243whp on a pretty much stock b16 with dyno tuning
... what?
you made about 100whp off a "pretty much stock b16" by dyno tuning it?
... what?
almost did the crvtec boost idea, i used a modified drag kit with the ball bering option</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! »</TD></TR><TR><TD CLASS="quote">guessing a boosted b16</TD></TR></TABLE>
