HONDA RACERS HELP!!!
Old Feb 14, 2005 | 08:37 PM
TURBO4drTypeR's Avatar
Default HONDA RACERS HELP!!!
Is anyone using 5-lug on their FWD Hondas? I have stage 5 axles but the outer spline needs to use the prelude/accord front hubs. I have the ITR 5 lug on my car and was wondering if you guys know if I can use the 5-lug Prelude hubs or the NSX hubs???
Please help if you can and Thanks!
Old Feb 15, 2005 | 06:25 AM
00ITR #543's Avatar
Default Re: HONDA RACERS HELP!!! (TURBO4drTypeR)
You can use the 99 and up JDM hubs. They are the 36mm splines. Circuit Works/ProDrive makes em with the extended studs, but mine have been on back order for a couple months now..
Old Feb 15, 2005 | 07:39 AM
Default Re: HONDA RACERS HELP!!! (00ITR #543)
But from what car? and are they 5-lug?
Old Feb 15, 2005 | 09:33 PM
00ITR #543's Avatar
Sorry 99 and up spec JDM ITR 36mm Hubs will work.
Old Feb 15, 2005 | 09:38 PM
Cool!!! Thanks alot for your help! Can anyone else confirm if the 97^ Prelude or NSX hubs will work cause thats all that I have access to
Old Feb 16, 2005 | 11:55 AM
h22 civic's Avatar
got a ek with 5 lug and i use dss stage 5 axels with no probs
Old Feb 17, 2005 | 11:20 AM
Default Re: HONDA RACERS HELP!!! (h22 civic)
The hubs that i got was 4-lug so I gave them to a friend to use. The axles I have use the bigger spline(accord/preludes) Thats why Im asking for some help
Old Feb 17, 2005 | 11:25 AM
SlowReaction's Avatar
Give dss a call i'm sure they could make it for you.
Old Feb 18, 2005 | 09:32 AM
00ITR #543's Avatar
I know the 97+ Prelude splines are the same as the JDM ITR, because people buy them to replace broken axles on their JDM 5 lug conversions. Only thing that I don't know is if the wheel bearing will press into the integra knuckle. I don't think that they will because I believe that the wheel bearings are different diameters, but i am not sure. I think if they were the same, people would using the prelude hubs and brakes for 5 lug conversions on Integras and Civics.
integlspwr2k
Feb 28, 2006 11:06 AM
RhdRicheeee
Feb 12, 2006 07:43 AM
marko_think
Mar 31, 2005 09:36 PM
ptsaurus
Mar 31, 2005 02:35 PM
chameleon
12
Oct 4, 2002 10:22 AM
