Cruise Control No Go
Old Feb 14, 2005 | 08:15 PM
gen4acclude's Avatar
Default Cruise Control No Go
I have a generation 4 accord ex 5spd. My cruise control light will come on when activated but when i set the cruise nothing happens. I have checked the cables and vaccum lines, fuses everthing looks good. any ideas
Old Feb 15, 2005 | 07:58 AM
fleetmack's Avatar
Default Re: Cruise Control No Go (gen4acclude)
i've got the same problem and am also stumped
Old Feb 15, 2005 | 08:44 AM
SexyKitten's Avatar
I would try to reset it,
When you have the cruise control button pushed, (highway)
try hitting the reset Button, not sure if you tried that.
the car should be set already at a cruise speed, already. Try using the accel and decel buttons ,, it should work.
Good luck
MEOW
JeN in Da BK
Old Feb 15, 2005 | 07:07 PM
hondadude's Avatar
brake pedal switch, clutch pedal switch, The next most common problem is the 'clockspring' in the steering column. not called clockspring if there is no airbag.
I used to have a PDF file of the entire check list......I'll look around
Nealva
Oct 12, 2016 04:23 PM
jimmydean06
Jan 1, 2014 01:23 AM
gripek
Honda S2000
Mar 18, 2009 11:58 AM
Dezmon
Mar 9, 2007 06:38 AM
willyd88
Jan 6, 2006 03:54 AM
