Went to the track on Friday
Old Feb 14, 2005 | 06:41 PM
sohcvtec1995's Avatar
Default Went to the track on Friday
Untuned d16z6 homemade turbo 7psi. With no traction.and a stock slipping clutch
R/t-.327
60'-2.467
330-6.483
1/8-9.794
mph-74.64
1000-12.615
1/4-15.033
mph-92.90
Old Feb 14, 2005 | 06:43 PM
BauleyCivic's Avatar
Risky Business
Default Re: Went to the track on Friday (sohcvtec1995)
Ooooo you're turbo now...good work
Times are , but its a 2.4 60ft so whatever.
Care to elaborate on the setup?
Old Feb 14, 2005 | 06:48 PM
Default Re: Went to the track on Friday (V-Tech Bauley)
Yea i finally went turbo. it is a 14b hf mani, dsm side mount, 450 dsm injectors, afc hack,dsm blow off. crank pulley, cam gear, 93 octane, 2200lb car, no ac, no ps. it was tuned for na setup awhile ago.
Old Feb 14, 2005 | 06:50 PM
it only put down 140whp befor. but i hope that im closer to 200whp when i hit the dyno again. I need a clutch, then dyno, then tires, then fix up the setup i got, like go FMIC, Better BOV. and other things.
Old Feb 15, 2005 | 07:51 PM
Bumpo for more suggestions on what to do next. I was thinking, of clutch, then dyno, then some tires. I am shooting for some low 14's high 13's.
Old Feb 15, 2005 | 08:41 PM
McNizzle's Avatar
nice get some better tires and get that 60' time down and you should be mid-low 14's... I was going to go up to the track on Friday but I need to replace a wheel stud on each front wheel. I'm ridin on 3lugs each wheel and dont think it'd be too safe at the track. Maybe ill see you up there in the future.
Old Feb 15, 2005 | 08:44 PM
Default Re: Went to the track on Friday (Chris M)
yea just pm me whenever you go. maybe we can get a group to go out there. i should be back out there in like march/ april hopefully my car will have the clutch and have some dyno time in by then.
Old Feb 15, 2005 | 08:46 PM
McNizzle's Avatar
Yes that would be cool. You are familiar with user toekneeg right? That would be cool if us three could get together, along with some other honda-tech peeps... Somewhere down the road we should set up a little meet or something, like around Battle of the Imports time.
Old Feb 15, 2005 | 08:52 PM
Yea i know token. he went to the first track event that i set up awhile back.
Old Feb 15, 2005 | 08:53 PM
isckeg's Avatar
are you satisfied with the 14b does it pull hard
Old Feb 16, 2005 | 11:39 AM
Default Re: Went to the track on Friday (isckeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by isckeg &raquo;</TD></TR><TR><TD CLASS="quote">are you satisfied with the 14b does it pull hard</TD></TR></TABLE>
yea for its size it is real nice. even at 7 psi its a very large difference.
Old Feb 16, 2005 | 11:56 AM
DJ_SaNdOz's Avatar
Are you planning on staying w/ teh hack ,or upgrading to something else?
Old Feb 16, 2005 | 11:58 AM
Default Re: Went to the track on Friday (DJ_SaNdOz)
May go hondata, or uberdata. Dnt know yet. i just dnt like having to pay like 8oo bucks for the fuel management on a daily driven street car.
EGk20pro
Aug 19, 2013 06:21 PM
CRXdan
May 15, 2005 10:05 PM
RedTT
Sep 11, 2004 09:49 PM
1badda
Feb 12, 2004 09:16 PM
AbaZ
Mar 10, 2003 10:26 PM
