Concern about Octane
Old Feb 14, 2005 | 06:15 PM
DubFat's Avatar
Default Concern about Octane
I have a '95 accord ex and it has been using 87 octane fuel since it has been bought...i talked to a mechanic and he said now that the car is getting to be over 10 years old that i should switch to a higher-octance fuel. does it make any difference? keep in mind i'm reving to redline at points (like 6400 rpms)...
thanks
Old Feb 14, 2005 | 06:20 PM
Nick H's Avatar
New User
Default Re: Concern about Octane (DubFat)
since the stock motor has very low compression, and you are using the stock ecu (unaltered fuel and timing maps), you do not need to raise the level of octane you are using in your motor...the higher octane merely resists detonation better, which is not a risk with your motor...my ecu has been modified to run extremely advanced timing, making it essential for me to run 93 octane...but 87 is fine for you...
Old Feb 14, 2005 | 07:13 PM
DubFat's Avatar
Default Re: Concern about Octane (Nick H)
makes perfect sense...thanks
Old Feb 14, 2005 | 09:43 PM
Bishop Don Shizzle's Avatar
Oh yeah I forgot I can edit my own title! Yay!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">since the stock motor has very low compression, and you are using the stock ecu (unaltered fuel and timing maps), you do not need to raise the level of octane you are using in your motor...the higher octane merely resists detonation better, which is not a risk with your motor...my ecu has been modified to run extremely advanced timing, making it essential for me to run 93 octane...but 87 is fine for you...</TD></TR></TABLE>
That about sums it up.
Old Feb 15, 2005 | 10:36 AM
TxTuner
Guest
Posts: n/a
Default Re: Concern about Octane (Bishop Don A. Shizzle)
Higher octane fuel is needed only when pushing serious hp (turbo apps, etc.) You can run on 87 till the wheels fall off.
Old Feb 16, 2005 | 12:56 PM
SexyKitten's Avatar
Default Re: Concern about Octane (TxTuner)
87 is fine!!
true dat TxTuner.. "till the wheels fall off"
Meow!
mix!
Jen in Da BK
Old Feb 16, 2005 | 03:56 PM
1-racer's Avatar
it really doesnt matter how old the car is, In fact the older the car and more miles on it the less compression it has so running the same octane would not hurt the car at all. Maybe just run a thing of fuel injector cleaner once in a while
CA121
Jul 6, 2011 09:34 PM
civichatch201
Sep 30, 2009 07:12 PM
rico892002
Jul 30, 2007 05:24 AM
hondaracin24
Mar 16, 2005 08:24 AM
Propulsion
Oct 19, 2003 01:35 PM
