A few problems I hope you can help with...
Okay, as you know I am putting my car back to stock right now. I have also decided to fix a few problems that I have been having fo rthe last 4 months or so. Namely my IAT and IACV have not been working. The wiring had to be extended when I had the JRSC on there, so one would assume that there was some sort of wiring error when doing so.
The grounds to both sensors are working fine. When testing them i get the same voltage as I do when testing to a chasis ground. The problem appear to be that neither sensor is getting power. Now I dont think it is my wiring, I am going to redo it while waiting for responses so we'll know for sure. Now is there anything else you can think of that would cause them to not get power? A certain blown fuse? A relay? They come off of the same main wiring harness, which also has multiple other sensors coming from it and none ofthe other sensors have issues.
Any thoughts are welcome.
And this is basically the last thing I have to do before I am stock again.
93eg2james
17
Dec 16, 2006 08:15 AM
JDMlyfestyle
Aug 30, 2006 10:15 AM
