Replacing halfshafts on a 1997 Accord.
Old Feb 14, 2005 | 02:33 PM
Calean007's Avatar
Default Replacing halfshafts on a 1997 Accord.
I looked up under the car recently and found the halfshafts, but I have a question for those who have done this job before. I see where the halfshafts connect to the tranny and the wheel, but on the wheel, I don't see what you take off to release or loosen the halfshaft from where it connects to the wheel. I have a Chilton's manual and it says this nut, or that wingnut, but as a beginning DIY'er, there are no pictures. I'm not going to buy another manual, because I thought that someone may have a resource online in the form of a link to share, or maybe can break it down for me. Thanks for any help.
Old Feb 14, 2005 | 03:31 PM
urbanlegend21's Avatar
New User
Default Re: Replacing halfshafts on a 1997 Accord. (Calean007)
you are referring to the spindle nut
#17 on the picture provided
I believe it is 36 mm
Old Feb 14, 2005 | 05:55 PM
Calean007's Avatar
Default Re: Replacing halfshafts on a 1997 Accord. (urbanlegend21)
That is a great! Just what I was looking for!
Now from the manual once you get that off and I think the braket that bolts to the frame, the side that fits in the tranny just comes out, or is it threaded in there?
Also, once I complete this job, how long could I drive on it without an alignment? I think I may have to wait as long as a week.
Old Feb 14, 2005 | 09:06 PM
95accordh22a's Avatar
its not threaded in
Old Feb 15, 2005 | 06:14 PM
Calean007's Avatar
Default Re: Replacing halfshafts on a 1997 Accord. (95accordh22a)
thanks man. BTW, while I'm down there I'm going to drain and refill the tranny with fluid. Since it's a manual it calls for Honda MTF Fluid, but chilton's doesn't say what else is used as an alternative. I'm thinking some type of motor oil, but I'm not sure. Thanks for any additional help. you've all been great.
Old Feb 15, 2005 | 06:17 PM
New User
others might not say so but we always stick with the Honda fluid, even in our race cars
Old Feb 15, 2005 | 06:22 PM
Calean007's Avatar
So I have to got the dealership for that...great...
Old Mar 3, 2005 | 05:15 PM
Calean007's Avatar
Just another question on this. When I do this job, where is the optimal place on the frame to put the jackstands to hold the car up? I'm just not sure and I don't want the thing falling on me, or damaging part of my car.
Old Mar 4, 2005 | 01:48 PM
businessmanph's Avatar
what is a halfshaft? if it breaks what are the side effects?
When I changed my rear brakes I tried to put the jack under the frame but, it bent it a little bit so i just put it on the lip on the side of the car. not safe but i couldn't find another way to do it.
Modified by businessmanph at 12:10 AM 3/26/2005
Old Mar 12, 2005 | 06:34 AM
Calean007's Avatar
Default Re: Replacing halfshafts on a 1997 Accord. (businessmanph)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by businessmanph &raquo;</TD></TR><TR><TD CLASS="quote">what is a halfshaft? if it breaks with are the side effects?
When I changed my rear brakes I tried to put the jack under the frame but, it bent it a little bit so i just put it on the lip on the side of the car. not safe but i couldn't find another way to do it. </TD></TR></TABLE>
You won't be able to drive it because you have no steering...
Thanks for the suggestion on jacking up the car. I had thought about that...
CivicSD
11
May 25, 2010 04:36 PM
DVF2001
May 6, 2008 06:19 AM
delprad
Nov 21, 2007 01:59 PM
the-one1
Jun 3, 2003 11:10 PM
