install time/cost
Old Feb 14, 2005 | 01:59 PM
da'ee's Avatar
Default install time/cost
How long would a shop take to install cam gears,cams,pistons, and hone? How much would it cost?
Old Feb 14, 2005 | 02:20 PM
NJIN BUILDR's Avatar
Default Re: install time/cost (answer3)
If you mean pull the engine rebuild it and reinstall it Your looking at $2000 plus.If you have the engine out and disassembled your probably looking at around$800
Glenn
Old Feb 14, 2005 | 02:27 PM
drdisco69's Avatar
Default Re: install time/cost (NJIN BUILDR)
Man, I had a place here take my short block apart, inspect everything, hone and reinstall everything for $200.... I get the dealer hookup I guess...
Old Feb 14, 2005 | 02:37 PM
Default Re: install time/cost (drdisco69)
Shop are getting anywhere from $65-$100 an hour nowadays.He is also looking to get the head and cams etc.. assembled.If anything I'm probably a little low.Thank god Honda's are easy to work on ourselves.
Glenn
Old Feb 14, 2005 | 02:48 PM
drdisco69's Avatar
I didn't have them put the head on, I can screw that up myself, thank you very much.
Old Feb 14, 2005 | 02:57 PM
da'ee's Avatar
I dont think i was clear about my build. I have a GSR with the stock B18C1, I would like to put in new cams, new pistons, valvesprings, hone the walls(not bore), and new cam gears. How long would it take for a shop to put all these things in? About how much would in cost, in terms of best to worst case scenario?
Old Feb 14, 2005 | 03:10 PM
You are looking at disassembling the engine.Honing the block.Cleaning all the parts.Chaging the valve springs.Remove and replace pistons on the rods.Checking the clearences and reassembling.I don't see that happening in much less than 12-15 hours.At $75/hr thats $900-$1125
Glenn
Old Feb 14, 2005 | 03:29 PM
da'ee's Avatar
what about just cams and valvesprings.
Old Feb 14, 2005 | 03:32 PM
drdisco69's Avatar
This might not be an option for you, but have you considered doing some stuff yourself? A lot of this is not very complicated and you should have no problem learning something while you do it. I know this isn't for everyone, and that's why shops exist (and I get a paycheck) but just food for thought.
Old Feb 14, 2005 | 03:33 PM
3-4 Hours
namewasdallas
15
Sep 27, 2008 08:05 AM
FW_EJ8
13
Jan 4, 2008 07:00 PM
domestic abuser
Jun 7, 2006 04:50 PM
Spectrum24x
Apr 6, 2006 05:36 PM
ramz7887
Apr 15, 2003 05:30 PM
