jdm headlights
Old Feb 14, 2005 | 12:23 PM
Sidriver00's Avatar
Default jdm headlights
i recently put some jdm headlights on my SI and yea one points in the trees and the other points bout 1 foot in front of my car. Any tips on how to adjust these headlights b/c i lost my owners manual so i cant even find out how adjust the factory ones, yea im s**t out of luck.
Old Feb 14, 2005 | 12:51 PM
sockvtec's Avatar
Default Re: jdm headlights (Sidriver00)
you need to adjust the bulbs, somethign might be broken that isnt holding it in the proper place?
egg_baLLa's Avatar
im not sure but i think there should be screws on the back of your headlights that will adjust the beams. thats how mine is at least. u should check that out.
Old Feb 14, 2005 | 12:52 PM
jlacoy82's Avatar
71.192.16.183
Default Re: jdm headlights (egg_baLLa)
Yeah, should be little plastic looking gear things ont he sides/back of the housings to adjust the aiming.
Old Feb 14, 2005 | 05:36 PM
cock_diesel's Avatar
get em alligned by a shop, them have em warranty that shnizznaw
Old Feb 14, 2005 | 06:29 PM
Nsane1's Avatar
From: West Bakalakadaka St., Durka Durka Mohammed Gihad, WMDs
Default Re: jdm headlights (02'specvizzle)
there are two adjustments on the headlights but as far off as you say yours are I would say that either the bulbs are messed up or the way they were bolted up. I had to take my front bumper back off and play w/ the position I bolted the headlights up. The adjustment screws on the back of the headlights are mainly for fine tuning. You'll need either a #2 or #3 phillips head screwdriver.
Old Feb 14, 2005 | 06:58 PM
R-Lug's Avatar
Default Re: jdm headlights (Ball-Bearing)
it's in the manual and yeah,, you do adjust with phillips SD
Old Feb 14, 2005 | 07:14 PM
rodrez.'s Avatar
Pull your car up to wall, at night, and turn on your headlights. Using a screwdriver, adjust the headlights until they line up properly. When you installed the new lights, they were pushed out of alignment.
Old Feb 15, 2005 | 07:00 AM
Sidriver00's Avatar
thanks guys im going to test it out tonight
1337 Si
Acura TL, RL & ZDX
Feb 17, 2015 09:02 PM
Na-Spirit
Texas -OK -LA (Sales)
Oct 13, 2010 04:50 AM
hondahatch_nc
Nov 11, 2003 08:20 PM
Kellindal
Oct 21, 2002 11:43 AM
