engine building tools
Old Feb 14, 2005 | 09:49 AM
jweller's Avatar
Default engine building tools
are these any good? if not why?
http://www.use-enco.com/CGI/IN...-2216
they are on the less expensive side, but I hear enco has a good rep. I don't want to buy cheap junk, but I can't afford the best
I'm basicly doing a stock rebuild straight from the helms but I want to check everything.
If anyone has suggestions on some inside micrometers or dial bore gauges that are good but still not too expensive lets hear it.
or do i not even need them. I'm having the block honed so I can have the machine shop check the cyls for roundness. I can plastigauge the bearing clearances so I'm thinking I might not need to make any inside measurements.
Old Feb 14, 2005 | 10:57 AM
NJIN BUILDR's Avatar
Default Re: engine building tools (jweller)
It is probably the best of the low end stuff.Fine for occasional use.If they don't come with calibrating standards,you will want to get those also.
Glenn
Old Mar 29, 2005 | 07:09 AM
jweller's Avatar
Default Re: engine building tools (NJIN BUILDR)
anybody else got any thoughts on this before I buy them.
schock3
Nov 2, 2009 05:41 PM
Brujo13
Apr 10, 2009 10:28 PM
TheGsR99
Apr 26, 2006 09:52 AM
