Spark Plugs / Plug wires Repalcement. Any DIY instructions on the internet ?
Old Feb 14, 2005 | 09:45 AM
r3000's Avatar
Default Spark Plugs / Plug wires Repalcement. Any DIY instructions on the internet ?
I want to replace spark plugs and plug wires on my '95 accord LX. The plugs and wires i purchased from NGK. I've been trying to find installation instructions with pics on the internet .. no luck so far. I know that its pretty straight forward install, but still wanna make sure i do everything right. Any links, advices will be appreciated!
Thanks!
Old Feb 14, 2005 | 11:26 AM
TxTuner
Guest
Posts: n/a
Default Re: Spark Plugs / Plug wires Repalcement. Any DIY instructions on the internet ? (r3000)
This is definitely a flame-worthy post but I'm in a good mood
All you gotta do is remove the wires from your plugs and the dizzy. Take a 5/8 deepwell socket, extension, and ratchet and remove your old plugs. Put the new ones in and once they are snug, go a 1/2 turn more and they should be good. Put the wires back on (make a note of what point on the dizzy runs to what plug before you remove them) and your good-to-go
Old Feb 14, 2005 | 12:15 PM
SiEcO187's Avatar
Default Re: Spark Plugs / Plug wires Repalcement. Any DIY instructions on the internet ? (TxTuner)
Just replace one wire at a time and you should have no problems
Old Feb 14, 2005 | 01:27 PM
r3000's Avatar
Thanks for replying!
I've read that the plugs need to be lubricated before putting them in, is that true? Also, do i need to "gap" the plugs, or they are good to go (NGK V-power)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">This is definitely a flame-worthy post but I'm in a good mood
All you gotta do is remove the wires from your plugs and the dizzy. Take a 5/8 deepwell socket, extension, and ratchet and remove your old plugs. Put the new ones in and once they are snug, go a 1/2 turn more and they should be good. Put the wires back on (make a note of what point on the dizzy runs to what plug before you remove them) and your good-to-go </TD></TR></TABLE>
Old Feb 14, 2005 | 01:46 PM
alotawatts's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3000 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for replying!
A little bit of anti-seize lube on the threads is a good idea but not necessary. The premium type plugs are supposedly pre -gapped but check them anyway.
bobmugen
May 17, 2008 03:34 AM
kleen98accord
Oct 2, 2007 07:17 AM
red_honda_racer
Mar 1, 2003 09:42 AM
TeamTooQuick
Apr 17, 2002 04:07 PM
crookedletterd
Jul 29, 2001 08:40 PM
