need more info for ZC motor
Old Feb 14, 2005 | 09:37 AM
JDMEJCIVIC_CTR's Avatar
Default need more info for ZC motor
well i was told to go to search to look for info on the ZC dohc. i did that and i did find info so thanx. but looking drawed me to my next question i looked for the anwer but i didn't have any luck finding it so maybe ya'll might be able to answer it. You know how you can use a d15 with a d16 and a b18 with a b16. well is the anything that works with the ZC motor?
Modified by JDMEJCIVIC_CTR at 8:05 AM 2/15/2005
Old Feb 14, 2005 | 10:28 AM
packman's Avatar
Default Re: need more info for ZC motor (JDMEJCIVIC_CTR)
use what with what, trannys, ? i had one in my 93 civic what do you need to know
Old Feb 14, 2005 | 11:10 AM
Discosteak's Avatar
Default Re: need more info for ZC motor (packman)
it depends which zc you are talking about
Old Feb 14, 2005 | 11:49 AM
brentmc79's Avatar
try theZCresource.com
Old Feb 15, 2005 | 07:10 AM
for the DOHC ZC motor i wanted to know what is iterswapable with the motor. for example you go a d15 and put a d16 head on. you get what i'm saying? like all b series parts are universal to each other in the b code and all d series part and universal to any d coded motor? Hope i didn't loose you
Old Feb 15, 2005 | 07:25 AM
3RdT's Avatar
pistons,rods,tranny, n manifold for zc n d16 r interchangable. i can be wrong tho cuz i never owned a zc. jus wut ive read. but i believe theres also a sohc zc. which is a "jdm" a6 or something.
Old Feb 15, 2005 | 07:30 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Well really the Zc kind of has the desirable parts in it already, such as the highest stock domed D series pistons. It also has the DOHC head, which is actually unique to the ZC and 86-89 Integra D16A1 USDM engines. You cannot interchange the DOHC and SOHC D-Series heads without major modifications, and it still doesn't work so well.
If you're looking to upgrade the DOHC ZC then I'd look into aftermarket cams from Exospeed and whatnot.
Old Feb 15, 2005 | 07:35 AM
sockvtec's Avatar
you cant put a sohc head on a dohc block, otherwise i would definalty have a b16 head on my car
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: need more info for ZC motor (Burns)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burns &raquo;</TD></TR><TR><TD CLASS="quote">you cant put a sohc head on a dohc block, otherwise i would definalty have a b16 head on my car</TD></TR></TABLE>
I think you've got that backwards. You meant to say "you can't out a DOHC head on a SOHC block" right?
Old Feb 15, 2005 | 08:08 AM
93_cxEG's Avatar
hey i have a jdm zc motor...and if u want it i can sell it to you...
Old Feb 15, 2005 | 09:02 AM
civic4lif's Avatar
The Zc is basicly a D-series motor can use almost all d-series parts like headers and stuff like that you can also use pistons and rods and stuff, on mine im using d-series pistons and rods for my turbo setup when i do it
Old Feb 15, 2005 | 09:05 AM
93_cxEG's Avatar
Default Re: need more info for ZC motor (civic4lif)
oh yeah my zc is a jdm one and it is a dohc....
redlseg
Jul 17, 2005 05:59 PM
crxsijr
Apr 15, 2005 12:58 PM
#1nismo
Nov 20, 2004 11:57 PM
DarkZachiel
10
Sep 2, 2002 10:09 AM
