My first engine build. H1 motor. (fingers crossed)
Old Feb 14, 2005 | 09:20 AM
6ghatch's Avatar
Default My first engine build. H1 motor. (fingers crossed)
Well, I'm about 75% done my first engine build. After racing Honda Challenge H1 last season with a stock block b16a2 and Skunk2 stage 1 cams, I decided I needed more power . So my options were to pay someone to build me an engine (not really an option for the amount I wanted to do) or just dive in and learn as I go. I started out with a new ITR shortblock from Acura. Then purchased some tools I needed, rod bolt stretch guage, ring compressor, crank pully wrench, ect..
With help from the Helms, https://honda-tech.com/zerothread?id=991796, and http://forums.clubsi.com/showf...art=1 I took out the piston/rod assembly to be swapped to CTR pistons. After inquiring at every local speed shop around my area about the piston swap I decided to just send them to someone who knows Honda's, JE Import Performance. Got them back within a week then installed the new pistons and Mugen oil pan.
Next on the list was the head. I did not want to spend $1000+ on head work so I decided on a mild P&P and valve job. I contacted Ed from Ed's Racing Heads to do the work. He cleaned up the bowls and exhaust ports along with a valve job.
After the head was finished, assembly began this past Friday. I put on the head, installed the sensors,cams, gears, timing belt, throttle body, intake manifold, injectors, fuel rail, ect. Now I'm ready to get the engine off the stand, install the trans with new clutch/flywheel and drop it in the car.
Next thing on the list, I'll be taking it to JE Import performance for a once over, break-in and Hondata Tuning. Wish me luck!
Parts list:
B18c5 block
81mm CTR pistons
Mugen Oil Pan
Buddy Club stage 4's
Buddy Club cam gears
Rocket Gen2 springs and Ti retainers
RC 370cc injectors
B16a2 head
ITR TB and intake manifold
Toda header
Password JDM power chamber intake
Modified by 6ghatch at 5:34 PM 2/16/2005
Old Feb 14, 2005 | 09:34 AM
MI4$DC5's Avatar
SO gansta..i wish i had the guts to build my own motor, i tore down my first motor though.
Old Feb 14, 2005 | 10:12 AM
MikeSarr_GSR's Avatar
Default Re: (MI4DC2)
nice deal man that setups gonna make nice power. good luck!
Old Feb 14, 2005 | 10:27 AM
G U E C O's Avatar
Default Re: (MikeSarr_GSR)
Old Feb 14, 2005 | 11:10 AM
DonF's Avatar
Default Re: (stock93cx)
Very nice job.
Old Feb 14, 2005 | 11:42 AM
mrbsponge's Avatar
Default Re: (DonF)
wow man, that is freakin beautiful, and look at what you saved in the process, and what you learned. great job.
you might be the next skunk2 or somethin!!
i also built my last motor, after it took itself apart.......from the inside out.
good luck this season
Old Feb 14, 2005 | 12:04 PM
dragonz04's Avatar
Default Re: (mrbsponge)
nice job, i also wish i had the guts to build my own motor
Old Feb 14, 2005 | 12:44 PM
AK94GSR's Avatar
Default Re: (dragonz04)
looks really good so far man.....nice and clean
thats what i like to see
and it also looks like u started with all new parts
post up some dyno numbers once finished
Old Feb 14, 2005 | 01:07 PM
Cidone's Avatar
Default Re: (AK94GSR)
I have a B18C ITR and want to put CTR pistons in mine but a local shop said it would be around $1500 if the motor is out and like $2500 if the motor is still in the car... Do you have any advice for me... hahah
Old Feb 14, 2005 | 01:10 PM
Big Teggie's Avatar
Good work, nice pictures
Old Feb 14, 2005 | 01:14 PM
B18civic5g's Avatar
Default Re: (Cidone)
nice
should make some great power!
what you going to use for tuning?
Old Feb 14, 2005 | 01:35 PM
junkyard racer's Avatar
Default Re: (B18civic5g)
hope you dont mind me asking...you seem to be on a budget, how much do you have in everything....
Old Feb 14, 2005 | 02:21 PM
hybrid_vtec's Avatar
Default Re: My first engine build. H1 motor. (6ghatch)
Lookz good
I'd like to see what it makes power wise!
Old Feb 14, 2005 | 02:26 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: My first engine build. H1 motor. (hybrid_vtec)
Very nice and clean!
Phantastic's Avatar
nice clean build.
Old Feb 14, 2005 | 02:37 PM
sleepycivichb's Avatar
looks great, keep us updated on how install went and dyno dates and such! -Jason
Old Feb 14, 2005 | 02:57 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (sleepycivichb)
Nice to see a local guy building a monster.
Old Feb 14, 2005 | 02:59 PM
MrTodd's Avatar
Wow... Just look at the crosshatch on those cylinder walls. Super clean.
Old Feb 14, 2005 | 03:11 PM
6ghatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18civic5g &raquo;</TD></TR><TR><TD CLASS="quote">nice
what you going to use for tuning? </TD></TR></TABLE>
Thanks, I'll be using Hondata for tuning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junkyard racer &raquo;</TD></TR><TR><TD CLASS="quote">hope you dont mind me asking...you seem to be on a budget, how much do you have in everything....</TD></TR></TABLE>
Well it's hard to say, I've sold stuff and have been helped out a little here and there. Definitely a whole lot less then a shop would charge.
Old Feb 14, 2005 | 03:27 PM
6ghatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cidone &raquo;</TD></TR><TR><TD CLASS="quote">I have a B18C ITR and want to put CTR pistons in mine but a local shop said it would be around $1500 if the motor is out and like $2500 if the motor is still in the car... Do you have any advice for me... hahah</TD></TR></TABLE>
Well, the problem lies with the time it takes to do it, although someone with experience could do it in a day. Most people would charge 20-30 hrs at $70-$90 per hour, that sounds about right. That is why I'm trying this myself.
But honestly If I had a good condition B18c ITR in my car I wouldn't spend the money for just for CTR pistons. There are plenty of other things you could spend your money on to gain more hp then what CTR's would give you alone.
Old Feb 18, 2005 | 06:40 AM
bigmouthcivic's Avatar
Default Re: (6ghatch)
nice job chris!
Old Feb 18, 2005 | 08:15 AM
ITRacer121's Avatar
I like it
reminds me of rebuilding my girls old LS motor
even thogugh your set up is a little more advanced then hers was
Old Feb 18, 2005 | 09:20 AM
Combustion Contraption's Avatar
Looks really good man!
Old Feb 19, 2005 | 01:33 PM
Skunk2Civic94's Avatar
Default Re: (LsVtec92Hatch)
i don't see the pics but i know you spent a lot of time on that thing..hope it doesn't break. Good job, Later
Old Feb 19, 2005 | 03:03 PM
Mike K's Avatar
that's gonna be a nice, powerful setup.
i'd like to see it with some toda A's or CTR cams in it , though. i bet that **** would ROLL.
