trans swap 90 civic hb 4 to 5 speed
Old Feb 14, 2005 | 06:06 AM
inetj's Avatar
Default trans swap 90 civic hb 4 to 5 speed
We have a 90 honda civic hb 1.5L that currently has a bad 4 speed. We would like to repalce it with a 5 speed. Will any (other than SI) 88-91 5 speed fit? What will I need to to the interchange?
Thanks.
-jg
Old Feb 14, 2005 | 07:21 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: trans swap 90 civic hb 4 to 5 speed (inetj)
You will want a 90-91 Civic Si tranny, or if you cannot find the Si then get a DX.
They both have the same gears, but the DX has a taller final drive, which makes it accelerate slower because it takes longer to get through the gears.
Both will bolt in the same.
Old Feb 14, 2005 | 07:27 AM
carsaregood's Avatar
Default Re: trans swap 90 civic hb 4 to 5 speed (B18C5-EH2)
http://www.gamesbbs.com/~dmoore/tranny.htm
if you are willing to get a new clutch/flywheel, you can widen your tranny options to any year, 88-91
Old Feb 14, 2005 | 07:45 AM
inetj's Avatar
Default Re: trans swap 90 civic hb 4 to 5 speed (carsaregood)
Thanks guys. Very good info. I think we are going to get the 91 trans. Not sure what it was out of (DX vs SI) but as long as it works we will be happy.
Thanks,
-jg
Old Feb 14, 2005 | 08:33 AM
sockvtec's Avatar
im just curious, what engine is that that comes with the std??
Old Feb 14, 2005 | 08:38 AM
SlAmMeD 91 HaTcH's Avatar
Default Re: trans swap 90 civic hb 4 to 5 speed (Burns)
It comes with the d15b1 70hp 4speed..
Old Feb 14, 2005 | 08:46 AM
inetj's Avatar
Default Re: trans swap 90 civic hb 4 to 5 speed (SlAmMeD 91 HaTcH)
Correct the standard trans.
Old Feb 14, 2005 | 11:40 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carsaregood &raquo;</TD></TR><TR><TD CLASS="quote">http://www.gamesbbs.com/~dmoore/tranny.htm
if you are willing to get a new clutch/flywheel, you can widen your tranny options to any year, 88-91 </TD></TR></TABLE>
Actually you can keep the bigger 90-91 spec flywheel and big clutch set-up if you run an 88 spec tranny.
How?
I run an 88-spec mainshaft ZC with a 1986 Prelude Si clutch disc and the 90-91 Civic Si pressure plate and flywheel.
The 1986 Prelude disc has the same shaft size as the 88-spec trannies, but has the surface diameter of the 90-91 Civic discs.
Old Feb 14, 2005 | 11:44 AM
daidilus's Avatar
LOL..i did this like 3 years ago..just get the 90-91 5 speed tranny, direct bolt up..nothing has to be changed
Old Feb 14, 2005 | 05:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
oooo, great info, thanks!
jaycorolla
Mid-Atlantic (Sales)
Aug 10, 2011 08:58 PM
cricketracer
18
Jun 30, 2009 10:40 AM
gm0nkey
Dec 19, 2004 06:52 PM
4gvtec
13
Sep 10, 2002 08:30 AM
RATEDR
Feb 13, 2002 08:14 AM
