H22a engine swap
Old Jan 17, 2002 | 11:21 AM
garados's Avatar
Default H22a engine swap
I'm planning on putting the Prelude H22a engine in my car in a long time and I want to be prepared.
#1) Does the H22 fit without custom motor mounts?
#2) If it needs different motor mounts, should I go with HASport or something else
#3) Do I need to remove things like the A/C to get the H22 to fit
#4) Will the h22a mate to a '95 gsr tranny or will that have to be replaced.
#5) If the tranny needs to be replaced, which should I get, i.e. Prelude, ITR and will it bolt in?
#6) If the transmission needs to be replaced, are there transmission mounts available and which sould I get
#7) Can I use my old ECU or do I need to do some wierd harness nonsense.
#8) If I go all out and do forced induction, will a supercharger from Jackson or Vortech or a turbo from Greddy or HKS fit or will I need to do some wierd stuff to the hood, firewall, etc to get everything to fit
#9) should I just forget about doing a h22 conversion and just rebuild my b18c1 when it breaks or should I go with the b18c5
Thanks
Old Jan 17, 2002 | 11:26 AM
Leimokei's Avatar
New User
Default Re: H22a engine swap (garados)
2) go with HAsports
3) yes you do
5) go with the prelude tranny
7) depends on the year, ODBI or ODBII
8) you can turbo it, but modification may be required..
imo, too much work....buy a B18C1 for turbo
Ek9kidd
Jul 31, 2006 09:42 PM
Plateus
Honda Civic (2001 - 2005)
Jun 12, 2006 10:40 AM
95integragsr1984
Dec 23, 2002 01:00 AM
Grimm
Dec 20, 2001 03:21 PM
