code 20 and 7 idle at 3k WTF? anyone?
Old Feb 13, 2005 | 11:41 PM
CR_VtecCRX89's Avatar
Default code 20 and 7 idle at 3k WTF? anyone?obd1 b16 swap
b16 swap just put in help......someone
Modified by CR_VtecCRX89 at 9:41 AM 2/14/2005
Old Feb 14, 2005 | 12:09 AM
Default Re: code 20 and 7 idle at 3k WTF? anyone? (CR_VtecCRX89)
i know what the codes are just need to no why the idle at 3k? did a ***** f'n search but no tango(search button way over rated)
Old Feb 14, 2005 | 12:10 AM
ridexstraight's Avatar
try calibrating ur iacv thats code 7? corect?
Old Feb 14, 2005 | 12:12 AM
Default Re: code 20 and 7 idle at 3k WTF? anyone? (ridexstraight)
wooooowww i mean tps my badd
Old Feb 14, 2005 | 12:20 AM
did i mention that i'm obd1? or done it matter?
Old Feb 14, 2005 | 01:18 AM
Default Re: code 20 and 7 idle at 3k WTF? anyone?obd1 b16 swap (CR_VtecCRX89)
3k why?!?!?!?!
Old Feb 14, 2005 | 04:34 AM
Mr_CRX's Avatar
Did you do a dpfi-mpfi swap?
When I put my motor in, it was idling at 3k too, and I remember throwing a code 7. Try fixing that and seeing if it goes down.
Old Feb 14, 2005 | 08:38 PM
Default Re: code 20 and 7 idle at 3k WTF? anyone?obd1 b16 swap (Mr_CRX)
everything fixed except the code 20 checked all fuses all good, batt and alt. goodwhat can this **** be?
Old Feb 14, 2005 | 08:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CR_VtecCRX89 &raquo;</TD></TR><TR><TD CLASS="quote">3k why?!?!?!?!</TD></TR></TABLE>
trottle body wasnt closed all the way got a new one and bam still code 20 **** f^ck.
Old Feb 14, 2005 | 09:37 PM
DieMaster's Avatar
Needs to be About 20% Cooler
code 20 is the ELD ive heard of problems with this. look on http://www.PGMFI.org it might help u out
Old Feb 14, 2005 | 09:47 PM
Rywire's Avatar
Default Re: code 20 and 7 idle at 3k WTF? anyone?obd1 b16 swap (DieMaster)
ELD is usually a ground, or if you had a b16a obdo before you prolly removed the pin from the eld location on the ecu. The obd0 pr3/pwo uses the eld location for the vtec sol I believe(dosent look for the eld on pwo/pr3 ecu), or it was the knock sensor, I forgot....
Was the ecu wiring all stock prior to the b16a swap?
Ryan
Old Feb 15, 2005 | 08:45 PM
Default Re: code 20 and 7 idle at 3k WTF? anyone?obd1 b16 swap (droppedcrxsi)
ya the wireing was all stock just converted it to obd1 cause i did have a b20vtec but that went ka-bluwey
Old Feb 15, 2005 | 09:00 PM
TIRENECK's Avatar
https://honda-tech.com/zerothread?id=1142676
Old Feb 17, 2005 | 02:45 AM
Default Re: code 20 and 7 idle at 3k WTF? anyone?obd1 b16 swap (TIRENECK)
THAT DOSENT TELL SHIET CODE 20 MIGHT HAVE FOUND OUT THE PROBLEM WILL POST BUT IF ANYONE HAVE AN ANSWER TO SOLVE MY PROBLEM JUST THE CODE 20 LETME NO
Old Feb 20, 2005 | 12:55 PM
ChibiT89's Avatar
any updates? code 20 is owning me too
Old Feb 22, 2005 | 06:35 PM
Default Re: code 20 and 7 idle at 3k WTF? anyone?obd1 b16 swap (ChibiT89)
SORRY FOR THE WAIT BUT GIVE LIKE 24 HOURS AND HOPEFULLY HAVE THE PROBLEM FIXED WORK OWNZ ME
Old Feb 22, 2005 | 07:14 PM
quicksol95's Avatar
check your vacuam lines
Old Feb 22, 2005 | 07:17 PM
DieMaster's Avatar
Default Re: code 20 and 7 idle at 3k WTF? anyone?obd1 b16 swap (slow90hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow90hatch &raquo;</TD></TR><TR><TD CLASS="quote">check your vacuam lines
LOL WTF!? code 20 has nothing to do with vacume!
wokamanbizness
Jan 18, 2009 10:35 AM
yz125rider21
12
Feb 12, 2007 04:49 PM
SiRkid
Feb 9, 2005 12:11 PM
crxY-49
Jul 1, 2004 06:26 PM
