jdm amber side markers?
ok so heres what i was wondering. i want to do the whole jdm side markers, but what whould be easier to do? buying the whole fenders with the jdm side marker in it? or doing the whole thing yourself? i know its cheaper to just get the side markers and the wireing kit, but is it better to do that or just get the whole fender ready to go from passwordjdm.com or the kit from there? if you have installed them which did you do? by the way i have a DA if that helps thanx.
Better to just get the sidemarkers n cut the holes yourself. If you get the whole fender, thats an extra $100 plus the cost of painting them. In the time it takes for you to take the bumper off, take the stock fenders off, install the JDM fenders, put the front bumper back on, then align everything so it fits right, you coulda just cut the holes and ran a few wires n been done with it.
well thats what i was thinking. because ill be getting it painted while my motor is out, ill just get the sidemarkers and do that before it gets painted. so just buy the lights and the wire set?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndgent3g »</TD></TR><TR><TD CLASS="quote">well thats what i was thinking. because ill be getting it painted while my motor is out, ill just get the sidemarkers and do that before it gets painted. so just buy the lights and the wire set?</TD></TR></TABLE>
Wire set? The side markers should come with the plug that the bulb plugs into, and behind the plug theres 2 wires. You just gotta extend those wires (use solder or butt connectors) to your turn signal bulb wires and splice them in.
well passwordjdm has a wire set for it. its like extra wire. i guess it makes it easier to install them somehow? i saw the steps on 2gic.com and it looks quite easy if you know what your doin. ill see how they turn out
drift2004
Apr 14, 2007 06:47 PM
