ITR and RS/GS/LS airboxes
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
Does anyone know if the inside of the ITR airbox is the same as the rs/gs/ls? Do they flow the same, or is the ITR made to flow alot more efficiently? I ask because I saw a thread where the jdm eg airboxes are a little smoother than the usdm eg airboxes. Anyone ever compare the ITR and rs/ls/gs? I'm also curious if the outside design is the same as well.
~jOEL
~jOEL
I'm 99% sure that the airboxes are the same between the Integra models. But the easiest way to confirm this is to call an Acura parts department and ask them if the airboxes have the same part number. Or maybe Mike K. from Naples Acura can tell you the answer.
[Modified by BSQ, 1:02 PM 1/17/2002]
