TRANNY GURUS help i wanted to mix gears and had ???S
Old Feb 13, 2005 | 05:24 PM
swaytec360's Avatar
Default TRANNY GURUS help i wanted to mix gears and had ???S
I have a b16 hydro tranny that has a bad 3rd gear and bad diff my buddy has a cable ls tranny and i wondered if i could put the ls diff and 3-5th gears in the b16 tranny thanks for any input
Old Feb 13, 2005 | 10:56 PM
Icey112's Avatar
Default Re: TRANNY GURUS help i wanted to mix gears and had ???S (swaytec360)
the diff. would take no time at all to change. but the rest good luck ls gears suck *** for all motor.
Old Feb 14, 2005 | 03:36 AM
swaytec360's Avatar
Default Re: TRANNY GURUS help i wanted to mix gears and had ???S (Icey112)
i have an itr tranny for my fun car this would be for my daily driver thanks for that important info though
Old Feb 14, 2005 | 08:27 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
yes you can mix them. direct swap out for the 3-5 main and counter gears and synchro sets 3/4 and 5/R. you have to swap out the 3/4 **** fork and use the ls fork.
if you do this let me know. i am looking for 3 and 4 and maybe 5th b16 main and counter gears for a gsr hybrid tranny im building.
Old Feb 14, 2005 | 01:29 PM
swaytec360's Avatar
Default Re: TRANNY GURUS help i wanted to mix gears and had ???S (not so civic)
cool i might swap gsr 3-5 in i have those laying around too ill let u know when i start putting it together
grnhatch94
Aug 6, 2007 09:33 AM
LST2
Dec 10, 2006 12:57 PM
baked_beanz
Aug 14, 2005 10:19 AM
jedi27sith
Mar 7, 2003 08:36 AM
