need help guys
Old Feb 13, 2005 | 05:15 PM
JDM RHD eg6's Avatar
Default need help guys
hey i have a 1.5 d15b vtec single cam vtec motor and i finished my swap,but the dizzy dont fit right, what kind of dizzy should i use? ill post pic soon for you guys.
any help would be great guys thanks
Modified by MrEF8 at 4:56 PM 2/24/2005
Modified by MrEF8 at 4:58 PM 2/24/2005
Old Feb 13, 2005 | 05:47 PM
crxnj's Avatar
Default Re: need help guys (MrEF8)
d16z6 will fit..(Im assuming you''re runnind obd1..)
Dont know what others ..>
Old Feb 13, 2005 | 06:07 PM
Default Re: need help guys (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">d16z6 will fit..(Im assuming you''re runnind obd1..)
Dont know what others ..&gt;</TD></TR></TABLE>
im running obd0, i swaped my d16a6 intake manifold and all that you know still need some help guys
Old Feb 13, 2005 | 08:53 PM
dubzz24's Avatar
It's probably like when you use the a6 dizzy on a z6 head. Only 2 of the bolts will line up.
Old Feb 13, 2005 | 09:18 PM
Default Re: need help guys (dubzz24)
im not using a z6 head im using a d15b head
Old Feb 13, 2005 | 09:20 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrEF8 &raquo;</TD></TR><TR><TD CLASS="quote">im not using a z6 head im using a d15b head</TD></TR></TABLE>
The jdm d15b vtec head is the same **** as a d16z6 head except the jdm motor has an aggresive *** cam..Comparable to a zex cam...
Old Feb 13, 2005 | 09:26 PM
sit220's Avatar
yea but thats an obd1 motor so u need an obd1 dizzy to make it right
but ur obd dizzy will work fine u can only use one bolt and the rest 2 dont need to be there use a clamp or something to keep the head and the dizzy toghrter
Old Feb 13, 2005 | 09:40 PM
Default Re: need help guys (sit220)
so i can use only 1 bolt for the dizzy and can i use a obd1 dizzy from the d15b and change some of the wiring around?
Old Feb 14, 2005 | 03:38 PM
sit220's Avatar
http://crx.honda-perf.org/arti....html
Old Feb 16, 2005 | 12:28 PM
so what is it that im looking at?
Old Feb 16, 2005 | 02:08 PM
sit220's Avatar
The A6 Dist. is NOT going to line up to the Z6 head, so you have several options here...either use the two side bolts with large washers to hold the assembly on, or do some creative metal fabrication to make it look better. This is entirely up to you. A suggestion would be to bolt it down with the same amount of room on either side of the bolts, incase you need to advance or retard yor timing a bit.
Old Feb 16, 2005 | 02:12 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sit220 &raquo;</TD></TR><TR><TD CLASS="quote">The A6 Dist. is NOT going to line up to the Z6 head, so you have several options here...either use the two side bolts with large washers to hold the assembly on, or do some creative metal fabrication to make it look better. This is entirely up to you. A suggestion would be to bolt it down with the same amount of room on either side of the bolts, incase you need to advance or retard yor timing a bit.</TD></TR></TABLE>
Yup, or go obd1, thats what I suggest!
Ryan
Old Feb 17, 2005 | 08:04 PM
thanks
Old Feb 24, 2005 | 03:56 PM
anymore out there
BLB
Mar 17, 2009 11:41 PM
KHMERXB0I213
Southern California
Mar 10, 2008 05:05 PM
thenick
Dec 28, 2006 08:42 AM
