please help with tach
Old Feb 13, 2005 | 04:32 PM
d98clturbo's Avatar
Default please help with tach
its a long story but ill try to keep it short... i recently put back in an f23 motor into my CL2.3 (previously was h22) the only prob now is that because i converted the the harness to obd1 to accomadate the 95 h22 i had to use the f22 ecu from a 95 accord...well now that i have the car running with the f23 motor and f22 ecu the only thing that is not working is the DAMN tach...where or what can i get a signal from to have my tach read the rpms of the motor
hope my question is clear..
your help is greatly appreciated
Old Feb 14, 2005 | 06:55 AM
JimBlake's Avatar
Default Re: please help with tach (d98clturbo)
Incompatible wiring? Can you get your hands on a wiring drawing for both car & donor?
In my '98 Accord, the tachometer signal comes from the ECU, not from the ignitor. Earlier years I think that signal came from the ignitor. So your car's wiring wants to get the tachometer signal from the ECU so it doesn't even have the blue wire from the distributor??
Old Feb 14, 2005 | 05:12 PM
d98clturbo's Avatar
Default Re: please help with tach (JimBlake)
because i have an obd2 motor there is no blue wire from the distributor to read the rpm (on obd2 engines the rpms is read from the ecu) and with the obd1 ecu that i have there is no blue wire to read the tach (because on obd1 cars the tach got its signal from the distributor)...is this correct?
Old Feb 15, 2005 | 03:28 AM
JimBlake's Avatar
Based on the couple cars I actually own... Yeah, I think that's correct.
Old Feb 15, 2005 | 05:57 PM
d98clturbo's Avatar
so basically i am screwed?
but what about the cars that are obd2 but have converted to obd1 (ie. 98 gsr that has converted to obd1 using the ecu from a 95 gsr)...how do they fix that problem?
Old Feb 15, 2005 | 11:33 PM
PrettyLude's Avatar
on obd2 cars they should have a tach signal wire somewhere in the engine bay with a funny looking connector close to it
Old Feb 16, 2005 | 04:02 AM
JimBlake's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">on obd2 cars they should have a tach signal wire somewhere in the engine bay with a funny looking connector close to it</TD></TR></TABLE>Yeah, but that wire comes from the ECU. His OBD-1 ECU doesn't know how to provide a tach signal to that wire.
With an OBD-1 ECU, don't you need an OBD-1 distributor to run? What did you do about the CYP, CKP, & TDC sensors?
4gen5thtime
Jun 20, 2009 07:45 AM
alex17
Nov 4, 2006 03:46 PM
crxrocks
Jul 9, 2006 10:25 AM
SOHC_MShue
Aug 10, 2005 02:07 PM
nonvtec
Apr 5, 2005 11:11 AM
