Whats the best tranny for a ls/vtec
Old Feb 13, 2005 | 04:08 PM
stp_acura's Avatar
Default Whats the best tranny for a ls/vtec
Whats up people i'm building a ls/vtec for my 1990 integra and I am undicided about the best tranny for the setup.
I was considering a gsr tranny, but I think that some modifications have to be done can yall guys help me out.
Thanks for your help.
Old Feb 13, 2005 | 04:10 PM
Dan GSR's Avatar
Default Re: Whats the best tranny for a ls/vtec (stp_acura)
92-93 GSR
Old Feb 13, 2005 | 04:13 PM
GEN2TEG's Avatar
Default Re: Whats the best tranny for a ls/vtec (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">92-93 GSR</TD></TR></TABLE>
Although the 92-93 GS-R tranny would be your best bet, they are hard to come by. Your other choices would be the JDM cable trannies which are more readily available than the coveted YS1 92-93 GSR tranny.
Look for a Y1, S1, or J1 cable tranny. These will all directly bolt up to your setup.
Good luck
Old Feb 13, 2005 | 04:18 PM
stp_acura's Avatar
Default Re: Whats the best tranny for a ls/vtec (GEN2TEG)
I found a generation 4 gsr tranny can I do something with that
Old Feb 13, 2005 | 04:19 PM
GEN2TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stp_acura &raquo;</TD></TR><TR><TD CLASS="quote">I found a generation 4 gsr tranny can I do something with that </TD></TR></TABLE>
So it's hydro. You would need to do a cable to hydro conversion, major pain in the *** plus it's pretty expensive.
bee18see1's Avatar
Generation 4?
Old Feb 13, 2005 | 04:21 PM
stp_acura's Avatar
Default Re: Whats the best tranny for a ls/vtec (bee18see1)
from a 97 gsr integra. would that work for my setup?
Old Feb 13, 2005 | 04:23 PM
stp_acura's Avatar
you say it's pretty expensive.
Like about how much will that cost me and most important is it that worth it?
Old Feb 13, 2005 | 04:35 PM
riceball777's Avatar
small spline clutch (90-91)
just get a cable b16 trannie such as the si, j1
these trannie have very short gears just like the itr but uses the small spline clutch and have weak syncro's
do not get the jdm y1 tranmission that came of the b16 crx trust me i have one on my car. that trannie has the longest gears out of all the b16 trannies. the y1 has longer gears and does not have the 4.4 final drive. the y1 has longer gears that the 94+ gsr trannies but the gears are still much shorter than a ls trannie
big spline clutch 92-01
theses trannies are the ones that you want. that have short gears, and that have the stronger syncros like the 94+ hydro trannies
upu can also get the 92-93 gsr ys1 trannie but your never going to find that
or you can get the b16 ys1 that came off the jdm DA integras
but the problem with geting a ys1 transmission is that you cant tell if its a b16 shorted geared trannie or a super long gear ls trannie cuz that both are ys1
Old Feb 13, 2005 | 05:43 PM
stp_acura's Avatar
Default Re: Whats the best tranny for a ls/vtec (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">small spline clutch (90-91)
these trannie have very short gears just like the itr but uses the small spline clutch </TD></TR></TABLE>
Would I be ablie to rev above the 7500 rpms because I hear you can't rev up no more than 8000 rpms with this tranny. Is this true?
Thank for your help
Old Feb 13, 2005 | 09:55 PM
old_school_dohcvtec's Avatar
those B16A cables trannies should be able to handle an 8k redline cause b16as rev to 8k
Old Feb 13, 2005 | 10:13 PM
LSvtec03's Avatar
Default Re: Whats the best tranny for a ls/vtec (old_school_dohcvtec)
i have a jdm ys1 on mine. i love it. gas mileage suffers on the highway, though.
Old Feb 13, 2005 | 10:17 PM
k20z's Avatar
* B A N N E D *
k20r transmission
Old Feb 13, 2005 | 10:18 PM
rough_draft's Avatar
Default Re: (ROFL COPTER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROFL COPTER &raquo;</TD></TR><TR><TD CLASS="quote">k20r transmission</TD></TR></TABLE>
Old Feb 13, 2005 | 11:22 PM
2ndgent3g's Avatar
here you go, its already been delt with. this may help:
https://honda-tech.com/zerothread?id=1107103
Old Feb 16, 2005 | 07:02 PM
stp_acura's Avatar
Default Re: (2ndgent3g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndgent3g &raquo;</TD></TR><TR><TD CLASS="quote">here you go, its already been delt with. this may help:
https://honda-tech.com/zerothread?id=1107103</TD></TR></TABLE>
Thanks alot man that was really helpfull I learnd alot about trannys I didn't know.
Good looking out
I'm going with a b16 with a obx lsd and ls 5th
Old Feb 16, 2005 | 07:07 PM
iH8RICERZ's Avatar
i personally think the gsr trans would be the best. On an lsvtec, you cant rev high. The b16a/itr gearing causes the car to rev quick, then you'd be going through the gears way too fast. If you only drag race, then do get a b16a trans....but for dailly driving, gsr trans would probably be more ideal for your set up... just my .02
Old Feb 16, 2005 | 07:39 PM
LSvtec03's Avatar
Default Re: (stp_acura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stp_acura &raquo;</TD></TR><TR><TD CLASS="quote">Thanks alot man that was really helpfull I learnd alot about trannys I didn't know.
Good looking out
I'm going with a b16 with a obx lsd and ls 5th </TD></TR></TABLE>
sounds like you'll enjoy it. i personally would think about the gsr 5th, but that's just me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote"> On an lsvtec, you cant rev high.</TD></TR></TABLE>
and why not?
Old Feb 16, 2005 | 08:04 PM
2ndgent3g's Avatar
^^^yeah id like to know that also, why cant you rev high???
Old Feb 16, 2005 | 08:06 PM
stp_acura's Avatar
Default Re: (LSvtec03)
You say I can rev higher and that exactly what I'm looking for and I also readed that is better for a daily driver an I'm one of those.
Like how higher can one rev with a gsr?
If I do get the gsr. I would put a obx LSD with the ls 5th or you think that would not be necesary what you think?
Thank for your help yall guys are really helpfull
Old Feb 16, 2005 | 08:11 PM
stp_acura's Avatar
Default Re: (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">On an lsvtec, you cant rev high. </TD></TR></TABLE>
Why not?
I readed that is not good to rev over 7500 that max 8000 rpms why is this?
Old Feb 16, 2005 | 08:13 PM
2ndgent3g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">i personally think the gsr trans would be the best. On an lsvtec, you cant rev high. The b16a/itr gearing causes the car to rev quick, then you'd be going through the gears way too fast. If you only drag race, then do get a b16a trans....but for dailly driving, gsr trans would probably be more ideal for your set up... just my .02</TD></TR></TABLE>
well as long as hes not driving around alot with just a b16 tranny. keeping it at high rpms all the time. for ex. like highway driving. if he get a gsr 5th gear he would be fine. just as long as you keep it on low rpms and take care of it on your daily driving days would make sense to me. just my 2cent
Old Feb 16, 2005 | 08:14 PM
2ndgent3g's Avatar
i think because of the rod ratio
Old Feb 16, 2005 | 08:57 PM
LSvtec03's Avatar
rod stroke ratio is not a problem on the ls block. it is mostly the rod bolts. and once those are upgraded, along with the oil and water pumps and timing belt, i dont see any reason not to be able to rev as high or (depending on setup) higher than a gsr.
sorry. back to topic.
projecthybrid04
Aug 9, 2009 02:05 AM
daevay
Sep 15, 2007 03:48 PM
Beau Gotti
Oct 3, 2006 09:32 PM
DC4xRacer
Aug 3, 2004 08:17 PM
