Which harness do I use??
I have a 90 hatch DX with a chipped p28 and a OBD0-OBD1 jumper. I swapped my distributor to OBD1, what harness do I need to buy to make the wiring a lot easier. My motor is Ls/VTEC, this is the last thing I need to get it running. Thanks.
use your regular dx harness, convert it to MPFI and then put the obd0-1 harness in at the ecu, take out the resestor box and then wire up the extra wires that are on the obd0-1 to your o2 + dist and vtec and you're set.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 85mm LS VTEC »</TD></TR><TR><TD CLASS="quote">The only thing is I got rid of the stock harness a long time ago. Will a 90-93 Integra harness work instead?</TD></TR></TABLE>
No.
The pin outs are competely different.
You're going to want to find a DX harness pretty quick.. to make it easier on yourself.
No.
