ZC DOHC <~> D16A6
My friend has a CRX with a DOHC ZC motor, it recently started messing up on him...big time...like for example...if he just sticks the key in, the sparkplug wires start shooting off, it also give a code for cam position, and it would rev up all high and rough and it will die if u let go of the gas.
So he said if his ZC clutch and flywheel fit my D16A6 i could have them.
My question is, does it fit or is it to way off. I heard of them fitting...thats why im asking.
it doesn't matter if it is a dx / zc / si etc clutch and flywheel...
it depends on the year of the tranny
88 / 89 are differnet from each other and then those 2 are diff from 90-91.
Sounds like he needs to check his timing belt alignment
phatrick2332
Mar 31, 2004 06:11 AM
