Fuel Tank: How do I clean it out when I install walboro fuel pump?
Old Feb 13, 2005 | 02:45 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Fuel Tank: How do I clean it out when I install walboro fuel pump?
I'm going to have to drop the tank on my DA to install a new fuel pump sometime. The car has ~240k on it, so I'm sure there's quite a bit of dirt/deposits at the bottom of my tank. My question is, what should I use to clean out the tank?
Old Feb 13, 2005 | 03:10 PM
PrettyLude's Avatar
i had used something similar to rust remover and it cleaned it up pretty well
Old Feb 13, 2005 | 09:26 PM
where can i find it?
Old Feb 17, 2005 | 04:29 PM
FairlightRacing's Avatar
Default Re: Fuel Tank: How do I clean it out when I install walboro fuel pump? (MugenDude)
Oustanding question. Bump for answer.
Old Feb 18, 2005 | 02:19 PM
JonnyCoupe's Avatar
Default Re: Fuel Tank: How do I clean it out when I install walboro fuel pump? (FairlightRacing)
Heres an Answer.
Dont bother, every tanks ive ever seen is cleaner than the day it was fitted.
Old Feb 18, 2005 | 09:17 PM
Really? I always thought that there'd be some sort of sediment at the bottom of the tank.
Old Feb 21, 2005 | 09:24 PM
Do_Ster's Avatar
Default Re: (MugenDude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude &raquo;</TD></TR><TR><TD CLASS="quote">Really? I always thought that there'd be some sort of sediment at the bottom of the tank.</TD></TR></TABLE>
as did i
Old Feb 21, 2005 | 11:16 PM
JonnyCoupe's Avatar
Default Re: (_OEM_)
Sediment of what exactly? Petrol makes an excellent solvent.
Old Feb 22, 2005 | 07:39 AM
Used2beAb16's Avatar
Default Re: (JonnyCoupe)
Theres got to be some kinda dirt somewhere cuz somethings gotta clog fuel filters!!
I have never seen the bottom of my fuel tank, but i have seen a few mercedes tanks and they werent too bad but they had low mileage.
Old Feb 22, 2005 | 07:52 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonnyCoupe &raquo;</TD></TR><TR><TD CLASS="quote">Sediment of what exactly? Petrol makes an excellent solvent.</TD></TR></TABLE>
What is the purpose of the fuel sock then?
What about the fuel filter?
Old Feb 22, 2005 | 08:43 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">
What about the fuel filter?</TD></TR></TABLE>
The fuel sock is to keep the pump from sucking in sediment;
the fuel filter is to catch anything that the sock may have missed
and keep it out of the injectors..
Mosy likely any dirt/sand you get comes from the storage tank
that the fuel comes out of..
PS&gt; after you drain out most of the gas
you can usually catch most of the trash with a paper towel..
Old Feb 23, 2005 | 06:41 AM
TurboLude97's Avatar
Default Re: (88DXCRX)
one way to help keep sediment out of your tank is to not fill up when you see the tanker pumping into the gas tanks at the station... when they fill the tanks it mixes all the sediment in their tanks up. so you just go to another station if you need gas that bad or just wait a day because with time the crap will settle in their tanks.
Old Feb 23, 2005 | 07:08 AM
tgreaves's Avatar
Default Re:
The gas tank in my CRX was rusted and had alot of crap in the bottom of it.. I just bought a new gas tank for $130 from a dealer on ebay, makes it alot eaiser that way..
Old Feb 23, 2005 | 07:47 AM
88DXCRX's Avatar
Default Re: (TurboLude97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLude97 &raquo;</TD></TR><TR><TD CLASS="quote">one way to help keep sediment out of your tank is to not fill up when you see the tanker pumping into the gas tanks at the station. </TD></TR></TABLE>
Good advice.. Also if the pump runs really slow or you see an
"Environmental Services" truck on the parking lot near the tanks,
that usually means there is a problem with water contamination..
Jonathan_ED3
May 20, 2008 03:04 PM
egmatt93
Feb 1, 2008 05:42 PM
Tyson
17
Dec 15, 2006 05:29 PM
bossman032
18
Jun 1, 2004 08:16 PM
