Type r connecting rod and GSR??
Old Feb 13, 2005 | 01:25 PM
vtecpower2000's Avatar
Default Type r connecting rod and GSR??
I have a 94 gsr that needs a new connecting rod.I orderd one from my local Acura dealer but they tell me that the gsr rods are not loger availeble and the where superseded to the Type r rod.Now I have (3) gsr rod and (1) type r rod...is there any diffence in then two.
Old Feb 13, 2005 | 03:37 PM
hybrid_vtec's Avatar
Default Re: Type r connecting rod and GSR?? (vtecpower2000)
I believe they are the same b/c the 2 block use the same crank!
Old Feb 14, 2005 | 03:39 AM
NJIN BUILDR's Avatar
The itr rods are much heavier.You will need to find a good used gsr or buy 3 more itr rods.The one heavy rod will throw off the balance of the engine
Glenn
Old Feb 14, 2005 | 06:25 AM
Default Re: Type r connecting rod and GSR?? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The itr rods are much heavier.You will need to find a good used gsr or buy 3 more itr rods.The one heavy rod will throw off the balance of the engine
Glenn</TD></TR></TABLE>
Damn, I didnt know that! Why would they be heavier? Seems the ITR engine would want lighter components and not heavier.
Old Feb 14, 2005 | 08:15 AM
Default Re: Type r connecting rod and GSR?? (hybrid_vtec)
The cranks are also heavier.Inline fours are more stable (less buzzy) with the proper weight cranks.Light weight cranks will accelerate faster but not as good at sustained rpm.The itr rods are heavier (stronger) at the big ends.
Glenn
Old Feb 14, 2005 | 10:07 AM
MikeSarr_GSR's Avatar
yea if you think about it also, the big end isnt reciprocating like the end with the piston... so being lighter at that end probably makes the difference. all I know is when I put in my ITR block in my GSR it revved up faster than my GSR motor. all else was unchanged (tears) im getting nostalgic. that was 65K miles ago... ive also had a 7lb flywheel on it for 45K of that. WHAT A DIFFERENCE.
Old Feb 14, 2005 | 10:17 AM
Lsos's Avatar
Default Re: Type r connecting rod and GSR?? (MikeSarr_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">yea if you think about it also, the big end isnt reciprocating like the end with the piston... so being lighter at that end probably makes the difference.</TD></TR></TABLE>
It seemed like it at first to me, too...but if you really think about it it reciprocates just as much as the small end, except instead of only going up and down it goes side to side, too!
Old Feb 14, 2005 | 11:14 AM
DonF's Avatar
Default Re: Type r connecting rod and GSR?? (Lsos)
The "R" rod is not going to be that much different. You do need to get them balanced, the GSR's to the "R" or vice versa.
Old Feb 14, 2005 | 11:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">yea if you think about it also, the big end isnt reciprocating like the end with the piston... so being lighter at that end probably makes the difference. all I know is when I put in my ITR block in my GSR it revved up faster than my GSR motor. all else was unchanged (tears) im getting nostalgic. that was 65K miles ago... ive also had a 7lb flywheel on it for 45K of that. WHAT A DIFFERENCE.</TD></TR></TABLE>
If you had the itr pistons,then you had more comp. than the gsr also.
Glenn
Old Feb 14, 2005 | 11:32 AM
Lsos's Avatar
Are the R pistons longer than the GSR?
Old Feb 14, 2005 | 11:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsos &raquo;</TD></TR><TR><TD CLASS="quote">
Are the R pistons longer than the GSR?</TD></TR></TABLE>
Using C-SPEEDRACING's numbers usdm p-72-ao (gsr) -.60cc dome
usdm p-73-ao (itr) +3.65cc dome
Glenn
Old Feb 14, 2005 | 11:43 AM
Lsos's Avatar
Ah, pistons...my bad, I thought you were talking about rods.
Old Feb 15, 2005 | 01:51 AM
-=Zeqs=-'s Avatar
The ITR rods are heavier than the GSR rods because supposidely, the metal composition is different. Dunno how true that is. Never actually held the two in my hands and compared.
As for another GSR rod...you considered contacting Len or acuraautomotiveparts.org to see if they can get a hold of them?
RITLINBOY-91.SI
Jun 23, 2012 07:24 PM
GYChris
10
Sep 11, 2009 06:51 AM
xparkesx
18
Mar 8, 2005 09:03 PM
leftySi9900
Jul 12, 2004 07:19 PM
DragInteg
May 3, 2004 05:42 AM
