clutch pedal problem!
Old Feb 13, 2005 | 11:52 AM
IntegraB18's Avatar
Default clutch pedal problem!
ok heres the deal..i did a auto to 5 speed conversion(b18c) on my integra and i used a 93 civic clutch pedal and clutch lines...now heres the problem....i used a brand new exedy clutch and a used gsr flywheel...now when i step on the clutch it doesnt engage until its damn near on the floor,and as soon as i start to lift up it grabs...becuz of this it makes it hard to get into gear and its hard to shift fast when im racing...what can be the cause of this...my guess would be that the flywheel was resurfaced too many times , becuz i dont know the history of the flywheel..and i tried to adjust the pedal and that didnt work...has anyone had this problem b4?...a friend of mine had the same problem and he switched flywheels and it was fine...but im lookin for other options b4 i take down the trans and change flywheels and to find out that its not the problem...any input would be great
Thanks
Old Feb 13, 2005 | 12:25 PM
NJIN BUILDR's Avatar
Default Re: clutch pedal problem! (IntegraB18)
I assume its a hydro.You have to bleed every last air bubble out off the thing.Its not easy.I bought a "speedbleeder" bleeder valve for the slave cylinder from NAPA.Its part number bk 675-1569.Its not listed for honda/acura so I had to do a little research for the number.I pumped about a pint of fluid to get all the air out.I have a full pedal now.
Glenn
Old Feb 13, 2005 | 04:18 PM
IntegraB18's Avatar
Default Re: clutch pedal problem! (NJIN BUILDR)
yes it is a hydro trans...so im assuming u had the same problem?...how does the speed bleeder work?...i guess ill try it out and hope it works....anyone else have this problem with diff solutions?
Old Feb 13, 2005 | 04:57 PM
96b18c's Avatar
could just be the air trapped in lines like they said, but did you inspect the shift fork/clutch fork when you put the tranny on, one time I thought it was air in my lines, it wasn't, then I thought it was the slave cylinder or clutch master cylinder and replaced them both, it wasn't, and then I pulled the tranny and my shift fork was bent/cracked. Rare but possible.
Old Feb 15, 2005 | 04:10 AM
IntegraB18's Avatar
Default Re: clutch pedal problem! (96b18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96b18c &raquo;</TD></TR><TR><TD CLASS="quote">could just be the air trapped in lines like they said, but did you inspect the shift fork/clutch fork when you put the tranny on, one time I thought it was air in my lines, it wasn't, then I thought it was the slave cylinder or clutch master cylinder and replaced them both, it wasn't, and then I pulled the tranny and my shift fork was bent/cracked. Rare but possible. </TD></TR></TABLE>
na i didnt inspect the fork but when i change the throw out bearing it seemed fine..i didnt notice anything...well im prolly gonna bleed the clutch like hell today and ill let u guys know if it works
Old Feb 15, 2005 | 04:50 AM
spoonek9's Avatar
Shouldn't really matter how many times the flywheel was resurfaced, as long as it was done right. How many times was it resurfaced though?
Make sure everything is OK, slave/master cylinders aren't leaking and lines are connected right. Trying bleeding the line again and lastly make sure the pedal is adjusted right.
Pinkyek
14
Dec 20, 2014 07:12 AM
keiserbikes
Transmission & Drivetrain
Nov 19, 2012 07:26 AM
tez94teg
Oct 10, 2005 05:48 PM
TuRbEeZy
Apr 4, 2003 10:14 AM
