Main Relay clicks like a Semi Auto SHOTGUN
89 civic dx :
alright when i turn the key to the run position the main relay starts
clicking like crazy . the engine cranks but does not fire. i have spark
and fuel just no start. no blown fuses, all connections ok, except
broken wire to 02sensor on exhaust manifold. what would cause something like this? any suggestions are helpful
From: spinning DnB till your head explodes,jersey/philly
this jsut happened to me and the car wouldnt even crank. it took me a month to figure out too, it was my ground to the starter. it jsut had a lil crack in it. check all ur grounds.
Ignition Starter Switch. When this goes out you can crank the motor over and it will start for approximately 1/2 a second. It can also screw with the main relay if there is a short in ignition wires or ignition switch itself. My guess would be either a ground or ignition switch. $78 plus tax at Checker Auto parts or your local parts store.
xxOldschoolxx
12
Mar 23, 2013 05:38 PM
