Are USDM ITR pistons good enough for skunk stage2s?
Old Feb 13, 2005 | 07:14 AM
one slow coupe's Avatar
Default Are USDM ITR pistons good enough for skunk stage2s?
I have the been offered ITR pistons with 10,000 miles on them for 100$
My question is will that give me a high enough compresion with a mugen head gasket to run skunk stage 2s?
Old Feb 13, 2005 | 09:45 AM
Default Re: Are USDM ITR pistons good enough for skunk stage2s? (Manuel)
Would I be better of buying CTR pistons with a mugen head gasket and flat valves?
What would my compression be around?
Old Feb 13, 2005 | 09:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel &raquo;</TD></TR><TR><TD CLASS="quote">CTR will be fine but I go with the JDM ITR Piston 11.1CR 81.mm and a 2 layer o.em head Gaskit </TD></TR></TABLE>
Do you know what the CTR cr would be though?
You see, im still debating on what kind of cams and pistons to use for my setup, I was going to do the USDM ITR pistons with s2s2... or possibly toda c's with CTR pistons and a hella alot of tuning so its streetable
What do u think..
Old Feb 13, 2005 | 09:57 AM
chameleon's Avatar
Default Re: Are USDM ITR pistons good enough for skunk stage2s? (Honda_b16a2)
check the CTR piston sticky on the top of this all motor forum you will see ctrs in a gsr motor will yield 13.2
Old Feb 13, 2005 | 09:59 AM
Default Re: Are USDM ITR pistons good enough for skunk stage2s? (chameleon)
13.2 thats alittle hihg for a street car, would JDM ITR pistons go good with toda c's
I know these are kinda basic questions but i just need help with my setup?
Old Feb 13, 2005 | 10:11 AM
You have a usdm b16a2 rigth! how mane meiles is on the motor is it all stock cam's piston?
You whant to build up a b16a I frien of my did on I help with the build up
it was a gen2 sir-2 b16a P30 long block put in JDM CTR Piston and Ring's over size 81.25 we fyuill build the block all oem part's on stock b16a cam's it bass line @ 170Whp 108tq with stock head skunk2 iantake manifold and cam's gear's Apex vafc ITR header and it was a street motor </TD></TR></TABLE>
Yes i have a USDM b16a2
I have 96,XXX miles
i want to get 200 whp with toda c's CTR pistons, is this possible?
GSR_hatch936
11
Jan 10, 2008 12:06 PM
mugen12_35sec
Apr 13, 2006 04:20 AM
jdmjeff
Feb 20, 2005 08:18 PM
ACrite3404
Oct 9, 2004 11:22 AM
GOLDBERG
Jun 2, 2003 07:26 AM
