Where does the CKF harness connector plug into? **PIC**
I believe that one end of the CKF wiring harness terminates as a connector plug (not sure on this as I haven't physically looked at one for about 2 years now). Anyways, if you look at the pic, one end of the CKF is secured with a bolt.
My question is where does the other end of the CKF connect to??
I've heard that it leads up to and plugs into somewhere underneath the intake manifold area, is this true? I need to locate exactly where it plugs into.
The CKF shown in this pic is not plugged in. It is dangled downward and gets cut off by the pic.
Modified by Draggin99Si at 1:19 AM 2/13/2005
The CFK plug should plug up to your engine wire harness, it's a 3 wire plug withe the colors of WHT/RED-BRN/BLK-BLUE/RED. This is the colors for a 96-98 D16Y5, D16Y8 and 99-00 D16Y5 engines with M/T.
ive done the swap myself into a crx and i didnt use that and the car runs fine its jsut a knock sensor i think and its for obd2s, when you do the swap though to save time use the intake mani from the rex, and header and altenator cause they all have diff plugs (well not the header but you get my point).
B-serious
Jul 30, 2006 09:56 AM
