92 accord LX: No start, cant figure it out
Old Feb 12, 2005 | 11:31 PM
pyrosee's Avatar
Default 92 accord LX: No start, cant figure it out
OK. First: Battery died a few months ago, so I had it jumped, it started drove it home. I went to start it the next day and it just slow cranked and wouldnt start, so I drove my other car. I drove my new car for about a month and decided to try and fix my accord.
so one month later:
Step 1:
Replaced the battery.
result: Plunty of power, all accessories, lights turn on work fine. Except, the car just clicks. The starter does not engage at all.
Checked all fuses under the hood and the driver side kick panel. All were ok. Checked connection to starter, and everything was tight. Reconnected battery, made sure every thing was connected tightly.
Again, car would just click when I turned the key. And again, I tested all lights, accesories, radio, power, fans, etc. and all fine.
Step 2:
Pulled the starter.
Had it benched tested, it bench tested just fine.
Pulled the Alternator, had it tested and it was fine. ugh.
Put it back in, and same just click no-start.
Push started the car since its a manual, and it runs like a champ. Battery is charging 14+.
Let it warm up drove it on the freeway, drove it home, turned it off, and tried to immediately start it again, and CLICK.
So after reading these forums, I decided perhaps the rekay could be toast. Replaced the main relay, and still just a click.
So what's left? Neutral Safety Switch? Whats the easiest way to test that?
Any suggestions, ideas, or similar experiences?
I just dont get the fact that after the battery died and it was jumped is when the no start happened. Something just dont make sense.
Argh....
Old Feb 13, 2005 | 02:44 PM
pyrosee's Avatar
Default Re: 92 accord LX: No start, cant figure it out (pyrosee)
So I must have stumped ppl
Shop Time?
Old Jan 19, 2015 | 11:54 AM
NWsleeperswaps's Avatar
if its a 5speed pump the clutch 5 times then try this is to test the clutch sensor. if its an auto try switching between park and neutral. if thats not the cause i would check for good clean grounds and replace the wire from the battery to the starter solenoid. might check battery connections while youre there
Old Jan 27, 2015 | 06:44 AM
samim.malek's Avatar
Did you changed neutral safety switch...??
I have problem with my Honda accord 2007 - car wont start sometime...it will always start if i move handle from park to drive and then move back to drive to park...i am suspecting my neutral safety switch is bad..any one have any idea whats wrong??
carreragt
Oct 20, 2017 12:09 PM
03_artist
Oct 25, 2012 10:21 AM
andrew160
Aug 8, 2008 01:18 PM
Nessal
Jan 21, 2006 03:40 PM
pecusio
Aug 16, 2004 06:50 AM
