Question concerning valves
Old Feb 12, 2005 | 09:01 PM
akura404's Avatar
Default Question concerning valves
I had just bought a head that has skunk 2 springs, retainers, valves. I inspected the head pretty well before i had bought it. When i got home, I decided to do one last inspection on the valves just to see if they were bent. I did this by shining a flash light into the intake and exhaust ports to see if I saw any light in the combustion camber (IN THE DARK). Unfortunately, I did see the SMALLEST light on 2 of them (different combustion cambers). Could these valves possibly be bent or is this ok? Do the valves have to completely block off any light? I have never done this inspection to a completely stock head, so that's why i am asking for help. If anyone have any kind of idea, I would greatly be appreciate it. Thanks you.
Old Feb 12, 2005 | 10:24 PM
akura404's Avatar
Default Re: Question concerning valves (akura404)
Here are a few pictures of the head that I bought. Tell me what you guys think about the port and polish also? I think this port and polish was really really mild.
http://www.we-todd-did-racing....D.jpg
The exhuast side was pretty much the same. No major port, just nicely polished.
Modified by akura404 at 10:59 AM 2/13/2005
Old Feb 13, 2005 | 07:33 AM
akura404's Avatar
Has anyone ever done this?
Old Feb 13, 2005 | 08:30 AM
92WhiteHatch's Avatar
Spray some carb cleaner in the ports.If it leakes to the combustion chamber side they are not sealing,or may be bent.
Old Feb 13, 2005 | 10:06 AM
akura404's Avatar
Default Re: Question concerning valves (92WhiteHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92WhiteHatch &raquo;</TD></TR><TR><TD CLASS="quote">Spray some carb cleaner in the ports.If it leakes to the combustion chamber side they are not sealing,or may be bent.</TD></TR></TABLE>
Thanks for the reply. I tried what you said and the carb cleaner did leak through, but VERY, VERY slowly. I know that valves are suppose to seal pretty well to keep a good compression, but how well? Thanks
Old Feb 13, 2005 | 10:25 AM
sickerhatch's Avatar
you should be able to turn the head upside down and fill the combustion chambers with water and if it leaks around the valves you got a problem.
Old Feb 13, 2005 | 10:38 AM
akura404's Avatar
Default Re: Question concerning valves (sickerhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickerhatch &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to turn the head upside down and fill the combustion chambers with water and if it leaks around the valves you got a problem.</TD></TR></TABLE>
I will give that a try. In other words, all valves should seals up well enough not to let any kind of liquid through correct?
Thanks
Old Feb 13, 2005 | 11:58 AM
PyroProblem's Avatar
correct...valves should not leak at all...if they do you are losing precious HP...
Yes the port job looks to be somewhat mild but looks like its not a bad job,seems they just cleaned up the ports a bit, nothing drastic...
Old Feb 13, 2005 | 03:09 PM
akura404's Avatar
Default Re: Question concerning valves (PyroProblem)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem &raquo;</TD></TR><TR><TD CLASS="quote">correct...valves should not leak at all...if they do you are losing precious HP...
Yes the port job looks to be somewhat mild but looks like its not a bad job,seems they just cleaned up the ports a bit, nothing drastic...</TD></TR></TABLE>
Thanks for clearing this up for me. I'm going to put my stock valves in and see if there are any leaks. If it still leaks then i mush have a bad ported head. Thanks for the info.
clem kevin
Feb 26, 2009 01:09 AM
mobile chernobyl
Aug 8, 2008 12:36 PM
luis666
May 11, 2006 08:43 PM
jdmjeff
Dec 21, 2005 02:18 PM
mr. wu
13
Jun 17, 2003 08:58 PM
