blowin blue smoke @high rpm
no, head gasket means your burning coolant, wich is white smoke. blue smoke means your burning oil. most vtec motors burn a little oil while in vtec. if your motors not vtec, your rings could be going out a little bit. i was burning a little bit of oil, so i bought some restore 4 cylinder formula, and it works great. its about 6 dollars at autozone, or whatever car parts store you go to. ide definitely give that shot. and if its black smoke, its running rich (toomuch fuel) just for further advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my93hatch »</TD></TR><TR><TD CLASS="quote">what about maybe changing the valve cover gasket?? could that be the problem? i think it's comin out of my tailpipe cause i can in the rearview...</TD></TR></TABLE> Changing the valve cover gasket will not fix this problem if it is coming out of the tail pipe. If you smell oil burning then that is another story.
couldnt the IAVC i think it is be broke and leaking there, my friends gs-t leaked oil out of it and it looked like it was from the vavle cover gasket so he just replaced both and its all good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gobblebox59 »</TD></TR><TR><TD CLASS="quote">couldnt the IAVC i think it is be broke and leaking there, my friends gs-t leaked oil out of it and it looked like it was from the vavle cover gasket so he just replaced both and its all good.</TD></TR></TABLE>
The IACV is on the TB/intake manifold, if you have oil in your IACV you've got bigger problems than you think.
timbo2132
Jun 14, 2004 08:32 AM
