Broke fuel rail bolt. Is this ok? :(
Old Feb 12, 2005 | 04:04 PM
T-RO's Avatar
Default Broke fuel rail bolt. Is this ok? :(
Well the nut kept turning...
Bolt snapped right off. Is this ok to leave alone or is it gonna cause problems?
Old Feb 12, 2005 | 04:19 PM
TeamNextGenChris's Avatar
Default Re: Broke fuel rail bolt. Is this ok? :( (T-RO)
you need to replace it since it holds the rail against the injectors,preventing a fuel leak.it's just a stud.pull off the fuel rail,then use a pair of vise grip pliers to turn it out.
Chris
Old Feb 12, 2005 | 06:10 PM
T-RO's Avatar
Sounds easy enough... all is not lost.
Old Feb 12, 2005 | 06:33 PM
SOHCD16y8's Avatar
make sure you do it soon though cause the engine vibration will cause a leak quick
Old Feb 12, 2005 | 06:36 PM
Unjockable's Avatar
New User
Default Re: (SOHCD16y8)
i don't see how that will cause a fuel leak. it's just holding the injector wires. vibration on the wires will cause a leak?
i don't even have that black injector holder and havn't had a leak for years.
but it's easy to replace so just fix it. good luck.
Old Feb 12, 2005 | 06:43 PM
SOHCD16y8's Avatar
maybe im looking at it wrong but i thought thats what hold the fuel rail down
Old Feb 12, 2005 | 07:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 &raquo;</TD></TR><TR><TD CLASS="quote">maybe im looking at it wrong but i thought thats what hold the fuel rail down</TD></TR></TABLE>
you are correct.you can see the stud to hold the injector loom right below the hole in the injector loom.
Chris
Old Feb 12, 2005 | 07:21 PM
KRaZee_TiNy's Avatar
I seen so many of those broken off and no leak except if you missing 2 and if it's the stud to hold the wire then don't worry about it. only way it leak is the seal. 2 Stud holding from each side is perfect.
Old Feb 12, 2005 | 07:32 PM
LSVtecEK1's Avatar
Default Re: Broke fuel rail bolt. Is this ok? :( (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">you need to replace it since it holds the rail against the injectors,preventing a fuel leak.it's just a stud.pull off the fuel rail,then use a pair of vise grip pliers to turn it out.
Chris</TD></TR></TABLE>
listen to this guy............you need to replace it or it COULD result in a gas leak and PROBABLY will in the near future.
Old Feb 12, 2005 | 07:46 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Broke fuel rail bolt. Is this ok? :( (KRaZee_TiNy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KRaZee_TiNy &raquo;</TD></TR><TR><TD CLASS="quote">I seen so many of those broken off and no leak except if you missing 2 and if it's the stud to hold the wire then don't worry about it. only way it leak is the seal. 2 Stud holding from each side is perfect. </TD></TR></TABLE>
Theres only 2 studs to mount the fuel rail to.
And yes, I'd replace that fairly quickly, shouldnt be a big deal to do though.
Old Feb 12, 2005 | 07:59 PM
Default Re: Broke fuel rail bolt. Is this ok? :( (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">
And yes, I'd replace that fairly quickly, shouldnt be a big deal to do though. </TD></TR></TABLE>
there are three studs that mount the fuel rail.there are two studs that hold the harness loom.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I seen so many of those broken off and no leak except if you missing 2 and if it's the stud to hold the wire then don't worry about it. only way it leak is the seal. 2 Stud holding from each side is perfect</TD></TR></TABLE>
all those three studs do is hold the fuel rail down to provide that seal so that fuel isn't spewing all over the motor as fast as the fuel pump can push it out.it won't leak as long as the two outer studs are still there,but why take a chance?don't be a lazy *** and leave it broke.
Chris
Old Feb 12, 2005 | 10:42 PM
EJ1_203's Avatar
i suggest u replace it cuz eventually its gonna leak bro and ur not gonna be a happy camper already happened 2 me then a o ring on my injector broke so i had fun b4 i had 2 go 2 werk and take it all aprat becuz i kept smelling gasoline
Old Feb 13, 2005 | 07:36 AM
jlacoy82's Avatar
71.192.16.183
Oh, theres only 2 studs that hold down the fuel rail on my y8 manifold.
Old Feb 13, 2005 | 07:51 AM
VALET dude's Avatar
Default Re: (jlacoy82)
just LISTEN and DO what TeamNextGenChris said and done deal . end of subject .
Old Feb 13, 2005 | 08:28 AM
T-RO's Avatar
Yep, its just a stud. I'm pulling one off a spare IM i have around here.
Old Feb 13, 2005 | 10:54 AM
T-RO's Avatar
Default Re: (T-RO)
All fixed. Thanks for the info. I didnt realize it was a stud until you guys mentioned it.
lilkim0121
Mar 17, 2022 06:34 AM
civictype-r
May 26, 2010 08:30 AM
4ghatch
Sep 2, 2005 08:19 PM
shivern
Dec 12, 2004 05:42 PM
