Pssssssh Noise!
Old Feb 12, 2005 | 01:25 PM
DaMmniTz's Avatar
Default Pssssssh Noise!
What is this noise coming from the engine? Just done a recenty swap and it was a huge hp increase, a little over double the hp, and when the car is in motion (moving ) there's this HISSING sound ( Psssssssssssh ) and ask you press the gas more, the HISSING sound gets louder. When you come to a complete stop, the sound decreases and then it's gone. This i all coming from the engine. I just put a new AEM short air intake. My car is a 90 crx hf. Is this normal? It's all motor, no turbo. sounds like turbo though. anyone knows?
Old Feb 12, 2005 | 01:27 PM
ssl2k's Avatar
get a video or atleast a recording.
Old Feb 12, 2005 | 01:35 PM
crxtreme89h's Avatar
Default Re: Pssssssh Noise! (DaMmniTz)
It's the intake sucking air.
Old Feb 12, 2005 | 01:38 PM
itellyawhat's Avatar
^indeed. mine does it too. Its like a whistle sound.
Old Feb 12, 2005 | 01:43 PM
kulangot's Avatar
Default Re: Pssssssh Noise! (crxtreme89h)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">It's the intake sucking air. </TD></TR></TABLE>
Old Feb 12, 2005 | 01:50 PM
DaMmniTz's Avatar
I kinda thought it was the aem intake also. I had a hf stock and it had less then 62 hp and it wasn't able to suck that much air in cause of the lack of horsie, but since this swap, i'm getting at least double the hp and maybe that's why the sucking of the air into the intake is what that hissing is!
Old Feb 12, 2005 | 01:52 PM
ssl2k's Avatar
What motor is it?
Yeah it's crazy like that...Those HF's are ****** beasts.... 8 valve heads turn me on.
Old Feb 12, 2005 | 02:00 PM
Burlyirishdude's Avatar
Default Re: Pssssssh Noise! (ssl2k)
Yumm......Hf's make the world go around....
Old Feb 12, 2005 | 02:03 PM
DaMmniTz's Avatar
Jdm ZC Dohc
Old Feb 12, 2005 | 02:06 PM
EJ2-Fluffy's Avatar
big vacuum leak
Jon
Old Feb 12, 2005 | 02:14 PM
DaMmniTz's Avatar
i kinda feel like i'm being joked at!? it's not funnie!
Old Feb 12, 2005 | 02:39 PM
aaronhume's Avatar
hey theres these belts called "gator back" goodyear belts you can get at action auto parts and they give my car a nice whislting sound, almost like a mini-supercharger or something lol. but I suppose those grooves on the belts are actually for cooling purposes.
Old Feb 12, 2005 | 03:06 PM
88B16Si's Avatar
Default Re: Pssssssh Noise! (aaronhume)
the grooves on those belts are for grip and you can get the gator back at almost any parts store like napa or kragens
Old Feb 12, 2005 | 04:08 PM
Default Re: Pssssssh Noise! (tigerfreak_99)
My HF stock still made the same sound as it does not with the B16. Well, the B16 is a little louder I guess.
Old Feb 16, 2005 | 01:59 PM
88B16Si's Avatar
my b16 whinds alot. i'm not sure if it's normal. just got the motor. i was told it's the tranny. those b16 trannies are monsters. that with a six puc disc, i tear up axles left and right.
Old Feb 16, 2005 | 02:35 PM
Reelizmpro's Avatar
big exhaust leaks sound like that too.
Old Feb 16, 2005 | 03:21 PM
.Thomas's Avatar
Default Re: Pssssssh Noise! (Reelizmpro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssl2k &raquo;</TD></TR><TR><TD CLASS="quote">...Those HF's are ****** beasts....</TD></TR></TABLE> aint that the truth
Old Feb 16, 2005 | 03:28 PM
d16efsedan's Avatar
Default Re: Pssssssh Noise! (flatblkCR-X)
my intake does the same thing sounds kinda cool though but after a while it gets annoying.....
Old Feb 16, 2005 | 04:25 PM
tpr's Avatar
tpr
Check the tube that runs into the side of the intake tubing and the other end is at the valve cover. If it is out it will whistle just like you describe. Look for a loose metal to rubber fitting near the throttle body. Bet thats it!
jr408
Mar 19, 2008 05:44 PM
jr408
Mar 19, 2008 09:39 AM
CurbSide
Jul 21, 2006 09:32 AM
Jaydeep
17
Jul 27, 2004 04:14 AM
PhreeStyleHB
11
Jul 23, 2004 07:47 PM
