question about the spoon stroker kit for b16b
Old Feb 12, 2005 | 01:23 PM
willyboyK20's Avatar
Default question about the spoon stroker kit for b16b
I got a few questions about this kit. I know it is strickly for the taller deck b16b motor but would it work in a b16a motor with a thicker head gasket?
I guessing it would give the same compression or more as putting ctr pistons in a b16a block.
Old Feb 12, 2005 | 02:45 PM
UncleD's Avatar
Default Re: question about the spoon stroker kit for b16b (willyboyD16)
No. A B16b has the same deck height as a gsr. If you put that kit in a b16A, you'd go right through your head....
Old Feb 12, 2005 | 02:47 PM
thevanitygroup's Avatar
Default Re: question about the spoon stroker kit for b16b (clean rice)
^Yeah, you would slap your pistons against the head immediatly.
Old Feb 12, 2005 | 08:36 PM
-=Zeqs=-'s Avatar
Default Re: question about the spoon stroker kit for b16b (thevanitygroup)
Basically a B16B is a destroked B18C. So by using the Spoon stroker kit...which gives you the same stroke as a B18C...and the same compression as a ITR with a 2-layer head gasket...you've basically created a ITR shortblock.
Old Feb 13, 2005 | 12:12 AM
Default Re: question about the spoon stroker kit for b16b (-=Zeqs=-)
that is what i thought
thanks for the info
Old Feb 22, 2005 | 08:14 PM
Takumi Fujiwara's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">No. A B16b has the same deck height as a gsr. If you put that kit in a b16A, you'd go right through your head....</TD></TR></TABLE>
A couple more questions about this:
1) Can I just drop this complete kit into a B18C?
2) Anyone know the difference between the kit for the ITR & GSR http://www.modacar.com/product...DAENK
3) What bearings are you supposed to use with these?
I'm considering this, if it's possible because I may have access to a bare B18C1, but it has no crank.
Old Feb 22, 2005 | 08:26 PM
327da9's Avatar
Yeah, plus buying a itr crank w/ aftermarket rods and pistons would be probably alot cheaper.
The only thing your paying for in that kit is the spoon bling.
davehewitson
Jul 21, 2005 09:40 AM
Yusuke
Sep 16, 2003 11:29 AM
kingfrost
Mar 4, 2003 06:23 PM
pacienzavtec
Sep 14, 2002 08:32 PM
Spartanic
Mar 5, 2002 05:55 PM
