CRX SWAP Questions
I have a 91 CRX that I would like to do a swap on. I'm gonna swap in a 91 LS motor. I have everything from the LS( complete car) . What parts do I need and need to do to make my swap work. I've done many swaps with obd1 and obd2 but never done an obd0 so any help will be appreciated....Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperek »</TD></TR><TR><TD CLASS="quote">I have a 91 CRX that I would like to do a swap on. I'm gonna swap in a 91 LS motor. I have everything from the LS( complete car) . What parts do I need and need to do to make my swap work. I've done many swaps with obd1 and obd2 but never done an obd0 so any help will be appreciated....Thanks</TD></TR></TABLE>
You need a B-series mount kit (azracemachine.com)
Shift linkage (azracemachine.com)
90-93 integra half shaft and axles
If you have a dx crx then you have to convert to mpfi..
Then to make it legal in Cali you have to convert to obd1 using a obd0-obd1 conversion harness,ond1 ls ecu,obd1 distributor,abd o2 sensor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">
Then to make it legal in Cali you have to convert to obd1 using a obd0-obd1 conversion harness,ond1 ls ecu,obd1 distributor,abd o2 sensor...</TD></TR></TABLE>
On the topic of axles, will the Integra axles fit into the DX/SI spindles? Just curious
