replacing lower ball joints...
Old Jan 17, 2002 | 02:22 AM
customx_'s Avatar
New User
Default replacing lower ball joints...
since those lbj are a pain in the *** to get out, can i just replace the boot? becuz thats all thats bad. the bj is still good. thanks
Old Jan 17, 2002 | 04:35 AM
Leo95SE's Avatar
Default Re: replacing lower ball joints... (mindtrix)
the ball joint boot?
nu uh, need to replace whole thing. its a packed piece with grease inside, not meant to have the ring come off. well, as far as i know, at least.
Old Jan 17, 2002 | 05:46 AM
bruthaboost's Avatar
Actually, you can just replace the boot. Plus the boots are cheap so I'd buy extra just in case you accidentally tear one putting it on.
Old Jan 17, 2002 | 06:18 AM
Leo95SE's Avatar
Default Re: replacing lower ball joints... (b18bpwr)
how?
do you need a set of ring pliers or something for the boot ring? also, how do you fill it with grease?
is this a honda stocked part?
Old Jan 17, 2002 | 06:53 AM
4wsB21a's Avatar
New User
Default Re: replacing lower ball joints... (Leo95SE)
actually, as long as the ball joint is still stiff and not loose, you don't have to replace that boot. you can leave it alone. i have had the boot missing on one of my lower ball joints for quite some time now and since i don't want to replace it and my mechanic said it doesn't have to be done yet, i haven't worried about it. he said as long as it isn't loose, then don't worry about it.
Old Jan 17, 2002 | 11:00 PM
customx_'s Avatar
New User
Default Re: replacing lower ball joints... (crxplus)
i can move the ball joint around becuz the boot has been torned off for a while now. all the grease looks like it leaked out already too. can honda press it out and press a new one in for me?
Old Jan 18, 2002 | 04:21 AM
Mista Bone's Avatar
D Tranny Guru
Honda can press it off, but so can you with tool rental from Autozone.
Old Jan 18, 2002 | 04:45 AM
I just used a set of needle nose pliers and gently opened the ring and pulled it off. I lined the new boot with grease, slipped it over the joint, and "rolled" the old retaining ring back on.
Old Jan 18, 2002 | 06:33 AM
Leo95SE's Avatar
Default Re: replacing lower ball joints... (Mista Bone)
here is a good trick
take off the control arm by removing the bottom ball joint, and the two top ones. disconnect brake lines too.
heat up the steel around the joint REAL good, get it red hot. took me about 3 mins with a small propane torch.
get a block of wood and a mallat ready, and put the block on the bottom of the ball joint over the bolt, and wack it real hard. it will pop right out. the new one can just get hammered in fromthe top, and use the wood again so you dont damage the joint.
retriever99
Jan 8, 2020 07:12 AM
Hala
Aug 8, 2009 10:31 PM
D16SohcVtec
14
Apr 12, 2009 09:23 AM
HatchSpeeD
Oct 20, 2008 09:36 PM
Rywire
Mar 11, 2004 12:21 PM
